Right, so. I have an xfx R9 290 DD overclocked to about 70 mhz, about equal to the power of a 290x, and it reaches quite high temps. 94 celcius under full gaming to be exact, and idles at 49-50 c. For my cpu cooling, I have a Corsair h110 with two Noctua something somethings (wow, can't believe I forgot the name of one of my parts!, I'll have to look back on pcpartpicker later).
My question is, Should I buy an nzxt kraken g10, aio mounter and use my h110 for my gpu? (I could use the rest of my money to buy a hyper 212 evo for my cpu (I do still have the stock cooler for a while though...)
The only issue i would have with this, is that I really like the look of the DD cooler in my system, and don't know how well a kraken would look in it.
Thanks!
Star Citizen referral codes, to help support your fellow comrades!
UOLTT Discord server, come on over and chat!
i7 4790k/ Bequiet Pure Rock/Asrock h97 PRO4/ 8 GB Crucial TT/ Corsair RM 750/ H-440 Custom/  PNY GT 610
Damn you're like a modular human being. -ThatCoolBlueKidd
https://linustechtips.com/topic/400657-r9-290-high-temps/
Thanks!
idk if the h110 is compatible with the g10
https://linustechtips.com/topic/400657-r9-290-high-temps/#findComment-5401112
Thanks!
Change thermal paste. I had the same problem with my 290x and changing thermal paste dropped load temps to about 77 from 92c
The BBQ: i7-4770 / 212x / Tri-X R9 290x 1075/1400 / MSI H87-G43 GAMING / EVGA G2 850W / Corsair Spec 03 / Samsung 840 EVO 250gb SSD / Toshiba 2TB HDD / 8gb Kingston DDR3 1600mhz
Peripherals: G710+ / G502 / Bose Companion 2 Series III / Audio Technica ATH-M40x / Sound Magic E50
Monitors: Dell U2414H
https://linustechtips.com/topic/400657-r9-290-high-temps/#findComment-5401131
NZXT says that most aio's are compatible, not just their kraken series. (even linus says it in one of his vids.)
https://linustechtips.com/topic/400657-r9-290-high-temps/#findComment-5401135
I did. I have some Antec formula 7 on it. (rather than that chalk i had to scrub off). And I am positive that I re-mounted the cooler back correctly.
https://linustechtips.com/topic/400657-r9-290-high-temps/#findComment-5401142
The temps stayed the same?
https://linustechtips.com/topic/400657-r9-290-high-temps/#findComment-5401160
yep, I still have a fair bit left though in case I decide to do this.
https://linustechtips.com/topic/400657-r9-290-high-temps/#findComment-5401178
https://linustechtips.com/topic/400657-r9-290-high-temps/#findComment-5401186
I also know that the xfx cooler is basically the lowest of the low, and it sucks (but it looks sooo nice.)
https://linustechtips.com/topic/400657-r9-290-high-temps/#findComment-5401188
Dont buy the nzxt bracket for a 290.Seriously dont.The vrms will melt
the vrm's already melt lol.
https://linustechtips.com/topic/400657-r9-290-high-temps/#findComment-5401192
The 290's are meant to reach them high temps, dont quote me but i think it was safe till like 95 degrees Celsius, i had the same card and found out after... and didnt like that so i just swapped since i could still return it.
I noticed that while playing gta v, My card throttles a little , or so it seems. I get slight stuttering. It is also pinned at 94 all the time. Except loading screens where it cools down a little. Both fans are running at 100%.
EDIT- temps according to msi afterburner
https://linustechtips.com/topic/400657-r9-290-high-temps/#findComment-5401200
yh i had the same, i always use to get 94, and what you said earlier about temps around 50, thats exactly what i got whilst idle...
So in short nothing is wrong with your card its just meant to get the hot unfortunately
https://linustechtips.com/topic/400657-r9-290-high-temps/#findComment-5401218
How is the VRM temps during load? Use GPU-Z to find out
https://linustechtips.com/topic/400657-r9-290-high-temps/#findComment-5401407
Any good validation programs to find out?   Suppose I could play gta for about 5 mins.... brb...
https://linustechtips.com/topic/400657-r9-290-high-temps/#findComment-5401462
alright, so after a violent police chace down a really laggy road ending in a grass covered hill, (witch gives all the lag)  I ended up with vrm1 at 88c and vrm2 at 66c
https://linustechtips.com/topic/400657-r9-290-high-temps/#findComment-5401502
That isnt bad actually
My VRM temps goes up to 90c if i do overvolting
I still think you should double check your GPU cooler's seating
https://linustechtips.com/topic/400657-r9-290-high-temps/#findComment-5401523
And remember less is more for thermal paste. Dont squeeze it too much
https://linustechtips.com/topic/400657-r9-290-high-temps/#findComment-5401528
hang on, I noticed that the gpu temp wasn't hitting 94 that time, so i didn't do it long enough,. When i re did it just now, I came up with my gpu at 94c, vrm1 at 102c, and vrm2 at 77c
https://linustechtips.com/topic/400657-r9-290-high-temps/#findComment-5401592
Okay nvm that's horrendous.... You should try underclocking your card tho....
Is your card OCed?
https://linustechtips.com/topic/400657-r9-290-high-temps/#findComment-5401628
Is your card OCed?
only the gpu, the memory is at it's stock speed of 1250 mhz. Most people wiht the xfx cooler buy cheap small heatsinks and apply them to the vrm because of that. the gpu is clocked to its max at 1050mhz. (1.095 ghz)
https://linustechtips.com/topic/400657-r9-290-high-temps/#findComment-5401637
I would suggest going with a g10 then.... or better yet the corsair variance of the g10 (hg10 i think) so you wont be affected by the VRM problems!
https://linustechtips.com/topic/400657-r9-290-high-temps/#findComment-5401646
phhhhh, my budgets $50 including cpu cooler (probs gonna go with hyper 212 evo) I will buy some of those vrm heatsinks and the kraken g10 has a 90mm fan right there so that's nice. I need only save up about $10 more for a cpu cooler (just bought the kraken). Thanks for your help!
https://linustechtips.com/topic/400657-r9-290-high-temps/#findComment-5401665
you should get the hg10 for like 40 dollars
http://www.newegg.ca/Product/Product.aspx?Item=N82E16835181085&cm_re=hg10-_-35-181-085-_-Product
vs kraken g10 for 50$ (newegg is out of stock)
hg10 solves the VRM issue
http://www.overclock.net/t/1525392/corsair-hg10-information-thread-r9-290-x-updated-with-blower-fan-off-temps
And then you can pick up your 212evo with the remaining cash :)
Good luck!
https://linustechtips.com/topic/400657-r9-290-high-temps/#findComment-5401712
There is even someone with an xfx 290
Thanks for sharing
Edit: 12/12/14 Just got mine! Running on r9 290 XFX Black Edition w/ H90 ...140MM rad biggrin.gif
GPU Temp at idle: 39C
GPU Temp at full load: 60C (max)
VRM Temp 1: 81C at full load with 20% fan
VRM Temp 2: 60C at full load with 20% fan
System Resolution: 3840 x 2160
https://linustechtips.com/topic/400657-r9-290-high-temps/#findComment-5401720
