GPU Liquid cooling
Solved by Carl2608,
We can recommend parts, but at the end of the day, it will come down to your budget, and availability of parts in your area.
generally as long as the threading is the same between all your parts, it will come down to looking at reviews (be it on the site, or on youtube)
edit: after looking at your parts, it would be wide to splurge on other aspects of you build. Your case especially is not going to have the internal space to properly route cables, and have a rad big enough to dissipate the heat of a cpu and a 780ti
try looking at the kraken g10, as you will spend less than a custom loop (it gets expensive real fast)
