I upgrated my old computer HP Compaq 8100 Elite with Kingston HyperX 3K ssd, becouse my motherboard don't have 3.0 sata i bought SATA 3.0 controller and SATA 3.0 data cable. I dont know why i have speed leak ? My ssd is running with 2.0 speed. Please help !
Speed leak...?
QUOTE ME IN A REPLY SO I CAN SEE THE NOTIFICATION!
When there is no danger of failure there is no pleasure in success.
https://linustechtips.com/topic/399160-ssd-speed-leak/#findComment-5379394
Does the controller come with driver software? It may need to be installed. SATA cables can transfer at whatever speed the SATA spec is. Does the controller have a BIOS you can get it before the PC boots to Windows? How are you testing that you only have SATA II speeds?
CPU: Core i7 4970K | MOBO: Asus Z87 Pro | RAM: 32GBs of G.Skill Ares 1866 | GPU: MSI GAMING X GTX 1070 | STOR: 2 X Crucial BX100 250GB, 2 x WD Blk 1TB (mirror),WD Blk 500GB | CASE: Cooler Master HAF 932 Advanced | PSU: EVGA SUPERNOVA G2 750W | COOL: Cooler Master Hyper T4 | DISP: 21" 1080P POS | KB: MS Keyboard | MAU5: Redragon NEMEANLION | MIC: Snowball Blue | OS: Win 8.1 Pro x64, (Working on Arch for dual boot) |
https://linustechtips.com/topic/399160-ssd-speed-leak/#findComment-5379423
It doesnt come with cd drivers. I benchmark it and it was like a error screen with the message. You are using your ssd with 2.0 speed.
https://linustechtips.com/topic/399160-ssd-speed-leak/#findComment-5379437
Model of your SATA III controller?
https://linustechtips.com/topic/399160-ssd-speed-leak/#findComment-5379440
PCI-E Express SATA3 SATA3.0 6Gb/s eSATA SATA III Card
No manufacturer model number or brand name? Where did you buy it?
https://linustechtips.com/topic/399160-ssd-speed-leak/#findComment-5379500
Which one?
Google finds 80000 results when searching that.
This?
I7 4790K @4.5 Ghz 1.294V
VALIDATION, MSI Z97 Gaming 7, 24GB DDR3 1600, Asus Strix 1070 8GB OC@ 2.2Ghz, Corsair graphite series 760T (Black), Cooler master V850, NH-D15 w/LNA ,1TB Samsung 850 Evo,  480GB Sandisk Ultra II SSD, 3TB Seagate Barracuda x 3, 1 TB WD Passport (Backup drive), 2 TB WD Passport (Backup Drive 2),  Windows 10 Pro x64 (uhg), Logitech G900 Chaos (Main), Steelseries Rival (FADE) (Courtesy of Edzel Yago, Thanks Ed), Steelsieres Rival 300 Hyperbeast Special Edition, Coolermaster Quickfire TKL (MX Blue), Razer Blackwidow Tournament edition (Greens).  Audio: Sennheiser HD598 SE, Edifier S1000DB, AudioEngine D1 DAC; Yamaha MG06X Mixer & AudioTechnica AT2020.
Phones; Daily drivers: Nexus 6P 64GB/iPhone 6 (Music), Apple Watch, Apple AirPods.
Laptop: 2015 Macbook Pro 13, 8GB of RAM, 2.7Ghz i5, 240GB Apple SSD.
Plex Server: i7 3770, Gigabyte Board, 16GB DDR3 1600, Asus Strix GTX 1050ti 4GB, 120GB SSD Boot Drive, 8 x 3TB Seagate Barracuda, Rosewill RSV-R4000 With 2 Rosewill Hot Swap 4x Backplane Bays, 1050 Watt Corsair HX Series PSU,Hyper T2, Windows 10 Pro
I also do Youtube, check me out!
https://linustechtips.com/topic/399160-ssd-speed-leak/#findComment-5380232
I..... But..... Get a real one and your issue should go away.
https://linustechtips.com/topic/399160-ssd-speed-leak/#findComment-5383237
yeah, i could buy a new computer too. It should go away. Common
I'm saying it's janky as hell and probably only has sata R2 on it, despite being advertised as R3.
https://linustechtips.com/topic/399160-ssd-speed-leak/#findComment-5389888
computer using my ssd with sata 2 speed
So how is it a "speed leak"? If you're thinking the bandwidth is somehow leaking from the cable, you're mistaken.
https://linustechtips.com/topic/399160-ssd-speed-leak/#findComment-5389974
