Need help with OS installation
Go to solution Solved by rafazafar,
Ah you first need to make the ISO. http://www.dvdtoiso.com/
Okay, so I am trying to make a bootable USB for windows 8.1. My windows copy is on a disc, so I'm trying to get it on the usb. To do this, I am trying to use Rufus, but when I put in the windows disc, I can't find any "ISO" file. All of the guides I have looked up talk about an ISO file but there isn't one, just a bunch of random folders.
My Build: i7-4790K, 212 Evo, Asus Maximus VI Extreme, Crucial Ballistix Sport 16GB DDR3-1600, Intel 730 240GB SSD, WD Blue 1TB, EVGA GTX 980Ti ACX 2.0, NZXT H440 Blue/Black, EVGA 650W 80+Gold.
Most of the time, it's not the computer, it's the person using it.
https://linustechtips.com/topic/398473-need-help-with-os-installation/
Download ImgBurn and use it to make an ISO of the disk:
http://www.imgburn.com/
Be careful of the adware it tries to install, it can be installed without them just pay attention when installing. You should be able to figure out how to make an ISO of a disk, otherwise look up a tutorial or ask here.
Once you make the ISO image you can use Rufus to put that on the USB.
An ISO image is an image of a full disk. It isn't present on the disk, but instead can be made from the disk and then used to make another identical disk.
I hope this helps :)
"PSU brands are meaningless, look up the OEM."
Thanks!!!
