Hello,
A few days ago, I opened my laptop to look at my HDD (5400rpm), I saw that I have a free slot (yay :D ) and I'm going to put an SSD in it.
The thing is my laptop is about 3-4 years old and has SATA 2 (3GB/s), bandwidth= 300mb/s
Which of the following SSD's would you guys recommend? Price wise , performance wise amount of writes and lifespan of the SSD
I don't know if the speeds that are listed are the real speeds that you get every time.
Note: As said before the connector is SATA 2, I know I will never fully utilize the speeds of the SSD because they are sata 3.
https://linustechtips.com/topic/398372-ssd-help/
850 Evo
01101110 01101111 00100000 01101111 01101110 01100101 00100000 01101100 01101111 01110110 01100101 01110011 00100000 01111001 01101111 01110101
Main Rig: i7-4790K | Corsair H100i | Asus Z97 | 16GB Ripjaws | 4TB WD Black/512GB SSD | x2 R9 290x | NZXT H440 | HX1000i | 6 Noctuas   [spoiler=SILENT BUILD] Silent build: i5-4460, Be Quiet! Pure Rock, Asrock H97, 8GB HyperX, Samsung 850 Evo 500gb, MSI GTX 970, Be Quiet! Silent Base 800, EVGA Supernova GS 650w
AMD CPU's. [spoiler=] thats right m8 get 420 no scoped
https://linustechtips.com/topic/398372-ssd-help/#findComment-5370137
I'd say the HyperX Fury
Early 2020 Build : Intel i7 8700k // MSI Krait Z370 // Corsair LPX 8x2 16GB // Aorus 5700 XT // NZXT H500
Early 2019 Build : Ryzen 2600X // Asus Tuff X470 // G.Skill Trident Z RGB 8x2 16GB // MSI RTX 2070 // NZXT H500
Late 2017 Build : Intel i7 8700k // Asus Prime Z370-A // G.Skill Trident Z 8x2 16GB // EVGA GTX 1080 Ti  // NZXT S320 Elite
Late 2015 Build : Intel i7 6700k // Asus Maximus VI Gene Z170 //  Corsair LPX 8x2 16GB // Gigabyte GTX 970 // Corsair Air 240
https://linustechtips.com/topic/398372-ssd-help/#findComment-5370151
Lowest power usage of them all and also good reliability. But the hyper X is also good. whichever you like. slightly better power consumption = sandisk ultra plus. speed = hyper x
just a note tho. the access times on the sandisk is lower than hyperX. but seq numbers arent as good.
https://linustechtips.com/topic/398372-ssd-help/#findComment-5370168
Well power consumption isn't a big of a deal since I always use my laptop plugged in.
I've compared the Sandisk with the Hyper X here and it seems the Sandisk is better in write and the same in read (capped at 300 MB/s).
I'm not sure if the site I used is a good one tho
https://linustechtips.com/topic/398372-ssd-help/#findComment-5370224
Yup thats a good real life benchmark site. I prefer the lower access times of the ultra plus even if its not as fast. really underrated ssd :)
the non "Ultra Plus" or "extreme" variation is really bad tho haha.
https://linustechtips.com/topic/398372-ssd-help/#findComment-5370237
Explain pls
Because, its in the middle, you get great performance, for a good price. thats all to it
https://linustechtips.com/topic/398372-ssd-help/#findComment-5370246
