I think it's best if you just get an air cooler until you fully understand and learn how a custom loop works.
If you just want liquid cooling regardless, just get an AIO.
You probably shouldn't watercool if you dont understand everything, google would help.
what air cooler do you guys recommend?
would have an answer if we knew what CPU socket it should be for :)
D.VA coming soon™ xoxo
Gulliver Nokia Lumia 1320
Werkfern Nokia Lumia 520
Hydromancer Acer Liquid Z220
Since the parts picker list says 1150 I'ma say its that one...
think it got edited or I need to sleep 'cause I'm blind
Youtube is your friend. If your not willing to invest 3 or 4 hundred dollars on a CPU water loop then look into an AIO cooler like an H100i if you really want it to be watercooled. I tend to recommend good air coolers over an AIO though because they offer similar performance.
  Custom Loop
4790K - Titan X - 16GB Vengeance 1866 - Asus Vii Hero - EVGA G2 850w - Samsung Evo 500gb - Corsair 760T - ROG SWIFT
