I'm thinking about building a small form factor computer to take with me to college.
I plan on doing some light gaming and maybe some graphics intensive games too.
I'd also like to keep it around $700.
Here's what I came up with: http://pcpartpicker.com/p/dgf823
CPU cooler is Cooler Master hyper 212 EVO
I'm also debating whether or not I want to run Ubuntu on it.
What do you guys think?
https://linustechtips.com/topic/397765-small-form-factor-godaveri-build/
Max cooler height for that case is 150mm, a 212 Evo is around 158mm so it won't fit. A Cryorig H7 will fit and has the added benefit of 100% RAM compatibility. It also performs well, looks great and is very easy to mount.
http://www.cryorig.com/h7.php
"The of and to a in is I that it for you was with on as have but be they"
Hyper 212 EVO won't fit in case.If you want a Mini-ITX case that fit's the 212 EVO then go with the Bitfenix Prodigy
Yeah thats probably a good choice
Probably too big for your case.
Noctua do some good small form factor coolers (E.g
My Rigs:
Gaming/CAD/Rendering Rig
Case:
 Corsair Air 240 , CPU: i7-4790K, Mobo: ASUS Gryphon Z97 mATX,  GPU: Gigabyte G1 Gaming GTX 970, RAM: G.Skill Sniper 16GB, SSD: SAMSUNG 1TB 840 EVO, Cooling: Corsair H80i PCPP: https://au.pcpartpicker.com/b/f2TH99SFF HTPC
Case:
Silverstone ML06B, CPU: Pentium G3258, Mobo: Gigabyte GA-H97N-WiFi, RAM: G.Skill 4GB, SSD: Kingston SSDNow 120GB PCPP: https://au.pcpartpicker.com/b/JmZ8TW
