Just renewed my Bell contract and looking to get one of these beauties.  Which one would you guys recommend?  Is the edge worth the $100 premium?
CPU -AMD R5 2600X @ 4.15 GHz / RAM - 2x8Gb GSkill Ripjaws 3000 MHz/ MB- Asus Crosshair VII Hero X470/  GPU- MSI Gaming X GTX 1080/ CPU Cooler - Be Quiet! Dark Rock 3/ PSU - Seasonic G-series 550W/ Case - NZXT H440 (Black/Red)/ SSD - Crucial MX300 500GB/ Storage - WD Caviar Blue 1TB/ Keyboard - Corsair Vengeance K70 w/ Red switches/ Mouse - Logitech g900/ Display - 27" Benq GW2765 1440p display/ Audio - Sennheiser HD 558 and Logitech z323 speakers
https://linustechtips.com/topic/397762-s6-vs-s6-edge/
there is actual difference between either the edge or S6 only the curved screen. so go with which one is a better deal.
Current Build :
CASE: Fractal Design R4 w/Window CPU: Intel 4930K,  RAM: 16GB Ripjaws Z 2133Mhz  Cooling: H100i  MotherBoard: Asus P9x79 Pro , PSU: CS750M   Storage: 2x Samsung 840 Pro 256Gb , 1Tb Seagate Barracuda, 500GB WD Black,  Graphics: Gigabyte GTX 780 Windforce 3GB,  Monitors: AOC G2460PG ( G sync monitor), Edge10 24" 1080p , 24" 1680*1020p monitor ( LCD)  Microphone: Blue Yeti  Keyboard: Cougar 700k  Phone: Samsung Note 3  Headphones: Sennheiser HD598
Laptop:
 CPU:
4710MQ  Ram: 8GB 1600MHz Storage:120Gb 840 Evo + 1Tb 5400Rpm HDD  Graphics: GTX 850M 2GB   Screen: 1080p IPS
https://linustechtips.com/topic/397762-s6-vs-s6-edge/#findComment-5362773
Yeah, I know there's not much difference.  Basically, I'm not someone who tends to upgrade his/her phone yearly, so I want to get the best device available knowing it'll last 2-3 years.  Do you think I'll miss out on the curved screen if I go with the regular s6?
https://linustechtips.com/topic/397762-s6-vs-s6-edge/#findComment-5362784
I love the Edge, personally. I think it's really cool.
If you want a phone that doesn't break the bank too much, though, the Edge is not your phone. It doesn't do much extra from the regular S6.
But I would personally get the Edge if I were to decide between the 2 and money is no issue.
The Workhorse (AMD-powered custom desktop)
CPU: AMD Ryzen 7 3700X | GPU: MSI X Trio GeForce RTX 2070S | RAM: XPG Spectrix D60G 32GB DDR4-3200 | Storage: 512GB XPG SX8200P + 2TB 7200RPM Seagate Barracuda Compute | OS: Microsoft Windows 10 Pro
The Portable Workstation (Apple MacBook Pro 16" 2021)
SoC: Apple M1 Max (8+2 core CPU w/ 32-core GPU) | RAM: 32GB unified LPDDR5 | Storage: 1TB PCIe Gen4 SSD | OS: macOS Monterey
The Communicator (Apple iPhone 13 Pro)
SoC: Apple A15 Bionic | RAM: 6GB LPDDR4X | Storage: 128GB internal w/ NVMe controller | Display: 6.1" 2532x1170 "Super Retina XDR" OLED with VRR at up to 120Hz | OS: iOS 15.1
https://linustechtips.com/topic/397762-s6-vs-s6-edge/#findComment-5363628
