So I've been building my first pc and after it booted up, I installed windows 7 64bit. I downloaded the appropriate drivers and turned my pc off, however when I went to turn it back on again 5 mins later the system powered up but nothing appeared on screen. I am a total noob when it comes to this so i will list any of my observations that might be important along with my specs
Specs
Asus r9 290
4x2 ddr3 1600mhz ram
3tb sea gate hdd
Intel i5 4590
Msi z97 gaming 3 mobo
Zalman z11 plus case
Asus optical drive
Observations
The red light for the hard drive flashes on and off very fast and somtimes is off for long periods of time
The speed of my fans when the pc was working appeared to be at full speed and was very loud however right now they are either very quiet or slightly loud (if that's a thing)
I've gave everything a quick check to make sure it's all plugged in correctly
I changed monitor just to make sure it wasn't a problem with the screen
( I tried unplugging everything and holding down the power button for a while to discharge the rest of the energy and plugging it all back in again and it worked for a while then stopped displaying anything on screen again)
I would greatly appreciate anyone that might be able to help me out
https://linustechtips.com/topic/397669-need-help/
Specs
Asus r9 290
3tb sea gate hdd
Intel i5 4590
Asus optical drive
Observations
I would suggest you post this at the Troubleshooting subforum of this forum.
Echelon Mk 2.11
  • Processor: Intel Core i5-6500
  • Cooler: Cryorig H7 (With a 120 mm Thermaltake Riing RGB)
  • Motherboard: MSI B150M Bazooka Plus
  • Memory: 16 (2x8) GB DDR4 Kingston HyperX Fury (Black)
  • Video Card: Sapphire NITRO R9 390 (Stock)
  • Storage:  1 TB Western Digital Blue
  • Power Supply: 520 W Seasonic M12II Evo (with custom extensions and cable combs)
  • Casing: NZXT S340 Elite (Matte Black)
  • Fans: 2x 120 mm & 3x 140 mm Thermaltake Riing RGB
  • Display: 22 " LG Flatron L227WTG-PF LCD (OCed to 76 Hz)
  • Keyboard: Logitech K120
  • Mouse: Logitech G402 Hyperion Fury
  • Mousepad: SteelSeries QcK
  • Operating System: Windows 10 Pro (64-bit)
https://linustechtips.com/topic/397669-need-help/#findComment-5361701
