Hey... I have a Hyper 212 EVO that I just got, and this is my first time installing an after market CPU cooler. I cleaned my surface using the ArtiClean thermal remover kit and put on a pea size drop. The 212 moved a ton when I tried to install so I remover it, cleaned it, applied new paste and tried again. Now that I'm on my computer, I have the fan running at full speed and the temps are about the same as before. Is this my 212's fault? Did I screw up the thermal paste? Do I need more fans?
Thanks
-Sam
Long time Linus fan with too many different forums to keep track of LTT's.
https://linustechtips.com/topic/397133-hyper-212-evo-not-doing-much/
What temp is it running at? Try stress testing it with heavyload then check temp
G3258 @ 4.5 | 8GB Team Vulcan RAM | 128GB Kingston V300 SSD (I didn't know what I was doing when I bought it) | MSI H81I Motherboard | Corsair H55 with Noctua NF-P12 | EVGA SSC GTX 960 4GB | OCZ 550W Fully Modular PSU with Noctua NF-A14 | Cooler Master Elite 130 (Soon to be something cool)
What were you doing to test the temperatures?
CPU: Ryzen 5 3600X            | Cooler: Deepcool AK400  | Motherboard: B550 Elite AX V2  | Storage: Samsung 980 Pro 1TB  |
RAM: Corsair Vengeance 16GB   | GPU: MSI RTX 3060 Ti    | Case: NZXT H440 (Red/Black)    | PSU: EVGA 650W G2             |
Might just need to snug it down a bit more. I had to crank mine a little tighter than I was comfortable with in order for it to set.
Also what paste did you use? Some of them need a cure time before they're 100% effective.
The New Machine: Intel 11700K / Strix Z590-A WIFI II / Patriot Viper Steel 4400MHz 2x8GB / Gigabyte RTX 3080 Gaming OC w/ Bykski WB / x4 1TB SSDs (x2 M.2, x2 2.5) / Corsair 5000D Airflow White / EVGA G6 1000W / Custom Loop CPU & GPU
The Rainbow X58: i7 975 Extreme Edition @4.2GHz, Asus Sabertooth X58, 6x2GB Mushkin Redline DDR3-1600 @2000MHz, SP 256GB Gen3 M.2 w/ Sabrent M.2 to PCI-E, Inno3D GTX 580 x2 SLI w/ Heatkiller waterblocks, Custom loop in NZXT Phantom White, Corsair XR7 360 rad hanging off the rear end, 360 slim rad up top. RGB everywhere.
Thanks
-Sam
did you tighten it correctly?
NEVER GIVE UP. NEVER STOP LEARNING. DONT LET THE PAST HURT YOU. YOU CAN DOOOOO IT
Thermal compound was included in the box, they are pretty tight. Used Prime95 and got 43C vs the older 46C.
What separates men and boys is when overclock big time. When the temp hits 60*C+ even with custom loop. Then you see the big difference between good and average coolers.
the evo has screws bottom out so don't be scared to tighten the screws all the way which is what your supposed to do. Make sure all 4 screws are bottomed out completely and remember a star pattern so it spreads easily. Also what are you using ? AMD or intel
The Ninja (current gaming pc)  Case- h440 red/black cpu- i5-4690k@ 4.3ghz cooler- coolermaster hyper 212 evo moboGigabyte z97x-sli ram- adata xpg v.1 2x4gb 1600mhz gpu- asus strix gtx 970 hdd- wd blue 1tb ssd- kingston hyperx savage 240gb psu- evga 600b peripherals: mouse- razer death adder 2013 keyboard- corsair k70 with chery mx-reds headset- HyperX Cloud 2
my laptop- toshiba satelite p850, cpu- i7-3630qm ram- 8gb 1600mhz hdd- 1tb 5400rpm gpu- Nvidia gt630m 2gb
did you know we have a gun thread ? well we do
and a car thread !
It's really not 43C... It depends on the program I use. Amd cpus never give the right temperature... Some programs say 80 some day 40. It's confusing
I use AMD- I didn't bottom the screws. I'll do that. Thanks
ya try that then tell me wHar happens
and a car thread !
