Hello all , I am new to the forum  and would like to inquire your vast knowledge to check if something is wrong with my first build.
The rig will be used primarily for gaming(1440p 60fps+) with a little bit of video editing.
http://pcpartpicker.com/p/3sj4Vn
---Case---
NZXT Phantom Red White
https://www.nzxt.com/product/detail/34-phantom.html
---Motherboard---
MSI Z97A Gaming 6
http://us.msi.com/product/mb/Z97A-GAMING-6.html#hero-overview
---CPU---
Intel I7 4790K
http://ark.intel.com/products/80807/Intel-Core-i7-4790K-Processor-8M-Cache-up-to-4_40-GHz
---GPU---
2x Gigabyte GTX 980 g1 gaming
http://www.gigabyte.us/products/product-page.aspx?pid=5208#ov
---Power Supply---
EVGA supernova 850w
http://www.evga.com/Products/Product.aspx?pn=220-G2-0850-XR
---RAM---
Corsair Vengeance Pro 16GB 2x8GB DDR3 2400MHz
http://www.corsair.com/en-us/vengeance-pro-series-16gb-2-x-8gb-ddr3-dram-2400mhz-c10-memory-kit-cmy16gx3m2a2400c10r
---SSD---
Kingston HyperX Predator 240GB PCIe
http://www.kingston.com/us/company/press/article/7547?Article-Title=HyperX-Launches-High-Performance-PCIe-SSD
---HDD---
2x 2TB WD Black 7200 rpm (maybe in raid 0)
---Cooling---
Corsair H100i GTX
http://www.corsair.com/en-us/hydro-series-h100i-gtx-extreme-performance-liquid-cpu-cooler
https://linustechtips.com/topic/397015-first-build/
---Case---
---Motherboard---
MSI Z97A Gaming 6
---CPU---
Intel I7 4790K
---GPU---
---Power Supply---
EVGA supernova 850w
---RAM---
---SSD---
Kingston HyperX Predator 240GB PCIe Gen2 x4
---HDD---
2x1 TB WD Blue 7200 rpm
---Cooling---
Corsair H100i GTX
What resolution and refresh rate are you gaming at?
I personally would go with a Noctua NH-U14S, better cooling, quieter, and no risk of leakage.
https://linustechtips.com/topic/397015-first-build/#findComment-5353416
Welcome to the forum!
may you tell us why you choose sli 980,i7 4790k and that ssd?
otherwise tell us what you'll be doing with that computer and what monitor you'll be used
I chose the sli 980 because a single 980 wouldn't be able to keep 60 fps + on 1440p ,
4790k is because i will be doing some video editing on the rig and i would  pay the 100$ premium for it over the i5
The ssd i because i want to play with a PCIe ssd.
I will probably game on 1440p G-sync monitor but not sure which one yet.
https://linustechtips.com/topic/397015-first-build/#findComment-5353497
1440p / 144hz?
for gaming you won't see any benefit with that ssd
you should tell us your budget and go on pcpartpicker.com to make your actual list of parts so we can give our recommendations more easily
Yes 1440p 144hz Monitor but i will aim for 60-70 fps. My budget isn't really set yet but it will probably be around 3k $
https://linustechtips.com/topic/397015-first-build/#findComment-5353771
