Help with Xbox One headset
Solved by ved,
Turtlebeach? Okay well your headphone jack either only has audio and no mic or both. It doesn't have two cables so that means you won't get the mic.
PopsicleHustler ·
Posted in Audio1 -
4
4
Greasy_Pudding ·
Sveeno ·
Posted in LTT Releases8 -
3
thrasher_565 ·
Posted in Hot Deals0 -
6
YoungBlade ·
Posted in CPUs, Motherboards, and Memory9 -
11
play_circle_filled
Latest From ShortCircuit:
