DAC or integrated sound?
Go to solution Solved by Oshino Shinobu,
Onboard audio is fine. It's rare for it to be unbearably bad, but obviously a DAC will still be better.
If you're on a budget, just stick with onboard audio.
Hello, Im building my first PC and with a job that doesnt pay too much Im on a budget.  I was wondering if the integrated sound would be enough to the point where it wouldnt be too much of a bother.
My motherboard of choice is the MSI a88x-g45 gaming
The cpu is a AMD Athlon II X4 860K
The gpu is a Auss Radeon R7 260X
And finally my case is a full tower
Would electric interference be too much of a problem in this build?
https://linustechtips.com/topic/396249-dac-or-integrated-sound/
for a dac that beats the onboard sound you have to spend much more
GUITAR BUILD LOG FROM SCRATCH OUT OF APPLEWOOD
- Ryzen Build -
R5 3600 | MSI X470 Gaming Plus MAX | 16GB CL16 3200MHz Corsair LPX | Dark Rock 4
MSI 2060 Super Gaming X
1TB Intel 660p | 250GB Kingston A2000 | 1TB Seagate Barracuda | 2TB WD Blue
be quiet! Silent Base 601 | be quiet! Straight Power 550W CM
2x Dell UP2516D
- First System (Retired) -
Intel Xeon 1231v3 | 16GB Crucial Ballistix Sport Dual Channel | Gigabyte H97 D3H | Gigabyte GTX 970 Gaming G1 | 525 GB Crucial MX 300 | 1 TB + 2 TB Seagate HDD
be quiet! 500W Straight Power E10 CM | be quiet! Silent Base 800 with stock fans | be quiet! Dark Rock Advanced C1 | 2x Dell UP2516D
Reviews: be quiet! Silent Base 800 | MSI GTX 950 OC
https://linustechtips.com/topic/396249-dac-or-integrated-sound/#findComment-5345292
