You might be able to get away with it, but I'd still recommend going with a fresh install. I'm not sure what driver changes take place between the two platforms, but a fresh install will make it easier to make sure you only have the necessary drivers and no leftovers from the old hardware drivers.
https://linustechtips.com/topic/39623-will-i-need-to-reinstall/#findComment-511173
I would recommend a clean install to avoid your new drivers conflicting with the old ones and causing problems.
Hello and Welcome to LTT Forum!
If you are a new member, please read the rules located in "Forum News and Info". Thanks!  :)
Linus Tech Tips Forum Code of Conduct           FAQ           Privacy Policy & Legal Disclaimer
https://linustechtips.com/topic/39623-will-i-need-to-reinstall/#findComment-511177
Windows 7 yes Windows 8 no
Specs: Core I7-2600K @ 4.5GHz @ 1.35V, 4x4GB Corsair Vengeance Black 1600MHz CL9, Cooler Master Evo 212, MSI Z77 Mpower Motherboard, Sapphire Radeon HD 7950 Vapor-X @ 1000/1400, Cooler Master HAF 932 Blue Edition w/ 3 Cougar Hydraulic Bearing 120MM fans (2 up top 1 in the bottom) replaced side panel with a window, and rear fan with a Cougar Hydraulic Bearing 140MM, Cooler Master GX 650 80+ Bronze PSU, Samsung DVD-RW, Samsung 840 Pro 128GB SSD, Seagate 750GB SATA III 7200RPM
https://linustechtips.com/topic/39623-will-i-need-to-reinstall/#findComment-511210
