Does it make more sense to say spend £100 on a headphones or does it make more sense to split that money and purchase a soundcard and a cheaper pair of headphones.
CPU: i5 4430 PSU: XFX 550w Ram: 8gb Patriot Viper 1600mhz
Motherboard: MSI H87M-G43 Case: Fractal Design Define R4
SSD: 840 Evo 250gb, 512gb MX100 GPU: MSI GTX 980TI Gaming Cooler: Hyper 212 Evo
https://linustechtips.com/topic/39568-headset-vs-sound-card/
Headphones first.  If your headphones don't get loud enough you can get a special amp, otherwise your onboard is fine unless you get high impedance headphones.  Headsets are not high impedance by any stretch.
"Pardon my French but this is just about the most ignorant blanket statement I've ever read. And though this is the internet, I'm not even exaggerating."
https://linustechtips.com/topic/39568-headset-vs-sound-card/#findComment-510414
I would go with the headset and get a soundcard later because you cannot really get a good £50 headset
Thanks for the response.
Thanks for the response, I meant headphones though thanks for reminding me :P
https://linustechtips.com/topic/39568-headset-vs-sound-card/#findComment-510429
Usually high end headsets include a usb sound card which shouldn't be that bad imo.
Hello and Welcome to LTT Forum!
If you are a new member, please read the rules located in "Forum News and Info". Thanks!  :)
Linus Tech Tips Forum Code of Conduct           FAQ           Privacy Policy & Legal Disclaimer
https://linustechtips.com/topic/39568-headset-vs-sound-card/#findComment-510435
Yeah, I sigh every time Linus screws that up in one of his videos.
https://linustechtips.com/topic/39568-headset-vs-sound-card/#findComment-510455
There is no such thing as a high-end headset really, at least I don't know of any. The 7Hs would be the best, though.
Now if we are talking headphones that is a different story.
Get headphones first, save for a soundcard. The lowest end "good" headphones you want would be something like the ATH-M50, and until that point you won't really have a set of headphones good enough to REQUIRE a soundcard (not that having one wouldn't help). Really whatever soundcard you get would be good enough. Even if its a cheap 50 dollar soundcard. the problem would be the amp (or lack there-of). I just got my Schiit Magni in the mail and love it. My friend has the Bravo Audio v2, payed 30 dollars for it, and it works LOVELY. So just some ideas.
https://linustechtips.com/topic/39568-headset-vs-sound-card/#findComment-510483
