Hey, going to build a comp for the first time, would be keen to get some advice. I was thinking of this -
Intel Haswell Core i7 4790 3.6GHz Processor
Gigabyte GA-Z97X-Gaming 3
750W EVGA SUperNOVA G2 Modular
Gigabyte Bluetooth 4.0 + AC Wifi PCI-E
Cooler Master Nepton 120XL
LG External DVD Writer (USB 2.0)
240GB Intel 730 Series 2.5" SSD
3TB Seagate Barracuda HDD
Zalman Z11
2x8GB Kingston HyperX Beast
Gigabyte R929OC-4GD R9 290 WINDFORCE
Razer Chroma
23" AOC Ultra Slim Monitor
24" Asus 144Hz 1ms Gaming Monitor
Please help me out if something doesnt look right, or if there is a better option, I have no brand preference for AMD v Intel so just have at it and tell me what to do, thanks a millions guys
https://linustechtips.com/topic/394997-first-build-please-help/
4790K.
don't like the case. Zalman is never the best choice.
2 or 4TB barracuda has better reputation.
Samsung EVO would be cheaper and you wouldn't notice a difference.
https://linustechtips.com/topic/394997-first-build-please-help/#findComment-5329247
4790K.
the zalman z11 PLUS is fine, not bad although not awesome. It will suffice especially if OP thinks it looks good.
CPU-i5 4690k 4.4ghz @ 1.190V, MOBO-MSI z97 gaming 3, Cooler-hyper 212 evo, GPU- r9 290x asus directcuII (-37Mv), Storage-120gb v300(switching soon), 1tb caviar blue, CASE-Red/black h440, PSU-Antec TPC 650.
https://linustechtips.com/topic/394997-first-build-please-help/#findComment-5329263
I have no idea what that means
ur motherboard is a board that supports overclocking but ur processor choice is not a K series processor. So you can't overclock it. Either buy the 4790K which can overclock or pick a different motherboard like a h97 board.
https://linustechtips.com/topic/394997-first-build-please-help/#findComment-5329282
Ah cheers, would you recommend AMD over intel? like a 4790K vs a FX-8350?
yes 100% yes
https://linustechtips.com/topic/394997-first-build-please-help/#findComment-5329295
What would you recommend over the zalman z11?
My cooler master had 912 works great
Happy to help with any tech problems. Windows 10 installing guide here.
----i5 4570s----gigabyte z97x-sli----8gb ddr3----gigabyte g1 gaming 960----HAF 912----120gb ssd----1tb hdd----500w evga----
https://linustechtips.com/topic/394997-first-build-please-help/#findComment-5329296
it all comes down to taste. If you like how the zalman looks then get it if you don't then get a different case something like the haf 912 or fractal design case
https://linustechtips.com/topic/394997-first-build-please-help/#findComment-5329301
why amd over intel when it shows that you have a i5-4690k?
read ur Q wrong :P i meant intel over AMD sos
https://linustechtips.com/topic/394997-first-build-please-help/#findComment-5329341
