So I just bought a new MoBo (AsRock H97M Pro4) and i went to their website to download the drivers. There's a lot of them and most of them i have no idea about. Need help on which ones are the essential that I would need to fully utilize it without getting all the bloatware(?). Same thing for my Graphics Card (Sapphire R9 280X Tri-X Vapor-X) (for some reason the print on the box is vertical, first time seeing it on this orientation. most videos/photos i saw had horizontal print on the box), what should i download on AMD's website?
Thanks
https://linustechtips.com/topic/394956-help-on-which-drivers-i-need/
Get the ones label "Chipset" and you should be good.  For the GPU drivers, you should be able to go to amd's website and look it up.
Happy to help with any tech problems. Windows 10 installing guide here.
----i5 4570s----gigabyte z97x-sli----8gb ddr3----gigabyte g1 gaming 960----HAF 912----120gb ssd----1tb hdd----500w evga----
Also try step #6 in my windows 10 installing guide in my signature[step 6 is the same for all windows versions]
id get.
Realtek high definition audio driver ver:7004
INF driver ver:10.0.21
Intel Management Engine driver ver:10.0.31.1000
Intel Rapid Start driver ver:4.0.0.1068
Intel Smart Connect driver ver:5.0.10.2907
Lan driver ver:19.0.27.0
Intel Rapid Storage Technology driver and utility
VGA driver ver:15.33.31.64.3993 isnt needed but could be nice if your video card ever durps...
System Specs
CPU: Ryzen 5 5600x | Mobo: Gigabyte B550i Aorus Pro AX | RAM: Hyper X Fury 3600 64gb | GPU: Nvidia FE 4090 | Storage: WD Blk SN750 NVMe - 1tb, Samsung 860 Evo - 1tb, WD Blk - 6tb/5tb, WD Red - 10tb | PSU:Corsair ax860 | Cooling: AMD Wraith Stealth  Displays: 55" Samsung 4k Q80R, 24" BenQ XL2420TE/XL2411Z & Asus VG248QE | Kb: K70 RGB Blue | Mouse: Logitech G903 | Case: Fractal Torrent RGB | Extra: HTC Vive, Fanatec CSR/Shifters/CSR Elite Pedals w/ Rennsport stand, Thustmaster Warthog HOTAS, Track IR5,, ARCTIC Z3 Pro Triple Monitor Arm | OS: Win 10 Pro 64 bit
Please spend as much time writing your question, as you want me to spend responding to it.  Take some time, and explain your issue, please!
If you need to learn how to install Windows, check here:  http://linustechtips.com/main/topic/324871-guide-how-to-install-windows-the-right-way/
Event Viewer 101: https://youtu.be/GiF9N3fJbnE
So i need none of the utilities? i got the Catalyst from AMD i didn't get the Beta drive since it says on the description that it's a Batman" Arkham Knight drive of some sort. but now that i am installing the Catalyst there's a lot of app that i have no idea if i need or not. i want this new pc of mine to be bloatware free
id get.
mind elaborating what those drives actually do?
i wont be getting the windows 10. i have windows 8.1
I know. Read the 2nd part. It's the same for all windows versions
im not going to claim I know what all of them do. to be honest with you and im not really going to research it all since I was about to boot LA Noire.
But from what I know.
Realtek is audio output simple as that
Lan is networking
VGA is video out from the motherboard.
Intel stuff I just get cause its never stuff that has annoyed me or been bloaty or obnoxious.
System Specs
Lan is networking
Thank you. Have fun on the game.
btw, do i just install this drives on a different pc then copy it on a usb, then just put it in my new build? or do i have to directly download it using my new build?
if basic things like keyboard, mouse, networking, video out is working just download them directly onto the machine you made and install them from there.
System Specs
also i found a video that says that you should install the mobo chipset first. which one is it on this mobo? it doesnt say anything on the choices it has
AsRock has some weird naming scheme. Chipset driver is listed as INF driver.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
