I'm designing a 2d platformer in unreal engine 4 and im trying to make a rope, in maya its a 2d surface that i made very tall and skinny, added 15 vertical vertices, and im trying to make it swing left to right and then import it into unreal engine 4.  Any ideas?
I can help with programming and hardware.
<Script>alert("This website is vulnerable to XSS");</Script>
https://linustechtips.com/topic/394855-very-simple-animation-in-maya/
dont know what format you need to import.
Edit :
1. Create the mesh
2. Export it as a .fbx (make sure that you use the 2013 version of the fbx exporter -> you can choose that in the export window)
3. Open the Unreal Engine 4 and click onto import
4. Choose your mesh, change some properties (e.g when you have lods, then you also have to enable "import lods") and then import it
5. Now save your textures that you have used for the mesh as a png/tga file
AMD 5000 Series Ryzen 7 5800X| MSI MAG X570 Tomahawk WiFi | G.SKILL Trident Z RGB 32GB (2 * 16GB) DDR4 3200MHz CL16-18-18-38 | Asus GeForce GTX 3080Ti STRIX | SAMSUNG 980 PRO 500GB PCIe NVMe Gen4 SSD M.2 + Samsung 970 EVO Plus 1TB PCIe NVMe M.2 (2280) Gen3 | Cooler Master V850 Gold V2 Modular | Corsair iCUE H115i RGB Pro XT | Cooler Master Box MB511 | ASUS TUF Gaming VG259Q Gaming Monitor 144Hz, 1ms, IPS, G-Sync | Logitech G 304 Lightspeed | Logitech G213 Gaming Keyboard |
PCPartPicker
Edit :
1. Create the mesh
still not getting it, at this point just the animation of the rope is whats causing me issues, not the exporting
