Hi forums so after thinking too much on a computer build I come here to ask for some help since I already pulled some hair along the process trying to figure out what´s the best for my needs.
Budget and Location:
- Preference below £1300;
- Portugal;
- Preference buying from outside the country since it ends cheaper than on Portugal;
Aim:
- Video rendering with Sony Vegas;
- Ability to record games with Open Broadcaster Software with good quality for YouTube;
- Two up to three weekly videos uploaded to YouTube is also one of the objectives;
- 1080p for YouTube is a must;
- Can run most games at 1080p 60fps with high settings;
- Soft video editing only;
Monitors:
- Need one monitor;
- Expecting something 60Hz, high response time since it´s for gaming;
- Good replacement for my current CRT Screen and that doesn´t hurt my back while moving it from time to time and that doesn´t strain my eyes so much on long sessions;
Peripherals:
- Need Operative System;
- Webcam although I got a Logitech c270 but not a must;
Graphic Card:
- Can either be AMD or Nvidia;
- Needs to run stable at 1080p 60fps on high settings on most games and upcoming ones;
- Prefer MSI for Graphic Cards but this is biased on reviews I saw so opinions are welcome;
Case:
- Good airflow;
- Easy to open and work it;
- Something that can last for several years;
- That I can have easy access to clean if needed;
Power Supply:
- Gold/Platinum;
- Either Corsair or EVGA;
- 550-650W Power Supply;
- Fully Modular;
Why are you upgrading:
-Current computer can´t handle 60fps 1080p on high settings let alone minimum on most; xD
- Upgrade from an i3 3,07GHz;
- Graphic Card ATI Radeon HD 5450 (1GB);
Additional info:
- This build is meant for a project that I will work on and will use Indiegogo Crowdfunding source to help me;
Prototype Build:
- Used only Amazon.co.uk for all the components;
Computer Dummy Build I did:
Monitor:
- BenQ RL2455HM;
Graphic Card:
- MSI Nvidia GTX 970;
Case:
-Corsair 780T;
Processor:
- Intel Core i5-4690k;
Solid State Drive:
- Crucial BX100 120GB;
Power Supply:
- Corsair AX760Watts;
RAM:
- HyperX Fury 2x4GB DDR3 1866MHz;
CPU Cooler:
- Noctua NH-D14;
Motherboard:
- MSI Z97 Gaming 5;
DvD Writter:
- Samsung 24x;
- Mostly for installing the Operative System;
Operative System:
- Microsoft Windows 7 Home Premium;
- Same as my current one but when I left to repair my computer once I left the Installation CD and it vanished on the process...-.-;
Hopefully you guys can help me out with a good build that does the same as the one I did that can lower the value but still keeping good quality components that I can count on.
On the Power Supply I tried to get the Superflower 650Watts Gold Fully Modular Supply, but funny is it ended £5 cheaper than the Corsair AX760 after the shipping fees,etc but I think I might overdid on the Power Supply.
Case and CPU Cooler are also one of my concerns but I don´t intend to overclock my CPU also I selected the HyperFuryX due to it´s automatic overclocking since I have no experience with this but any ideas on other RAM´s that can do the same works with me.
https://linustechtips.com/topic/394768-looking-for-computer-build-help/
That is a very good build.  You can spend a bit less on some components:
PSU - 760 watts is too much.  500 to 600 watts is plenty, unless you might do SLI in the future.  in that case, 600 is bare minimum.  Corsair Ax series PSU are very high end though, so you have picked a good one.
Cooler - definitely way more than you will ever need.  That cooler is for heavy overclocking.  Besides, you will get much more benefit spending that money on upgrading to i7 4790 instead.  Stock Intel cooler is totally fine.  I've been using it on my i5 4690k for 8 months now.
Case - 780T is a good case but very big and very expensive.  Around here, we LTT forum peeps like the Fractal Design Define R5, or the NZXT H440.  They are a good size, quiet, simple, very high quality, and good value.
OS - no need to spend money on new OS.  If you still have the key from your old Win 7, you should be able to download it and use your old key.  Or find a friend with the disc but use your key.  You will get free upgrade to Win 10.
DVD - you can probably omit this.  Load windows using USB stick.
everything else is fine.  Monitor is very hard to chose, but BenQ is good for the price normally.  HyperX Ram is good, and whatever SSD you can find on sale will be fine.  I recommend getting larger capacity and using it as your main drive.  It makes a big difference for programs and games.
i7 4790k @4.7 | GTX 1070 Strix | Z97 Sabertooth | 32GB  DDR3 2400 mhz | Intel 750 SSD | Define R5 | Corsair K70 | Steel Series Rival | XB271, 1440p, IPS, 165hz | 5.1 Surround
PC Build
Desk Build
Ok took your advice and changed some components and squeezed the value into alot less, however not sure a higher SSD Capacity will benefit me that much to be honest.
Also found my Windows CD-Key, now question is where can I get a clean download for the Operative System.
Is there anything else that can be changed or it´s ok like this?
So basically my computer build is the following now:
Monitor:
- BenQ RL2455HM;
Graphic Card:
Case:
- NZXT H440 (I looked at this one  couple times but was hesitant before because of the no dvd drive);
Processor:
Solid State Drive:
- Kingston SSD 120GB;
Power Supply:
- EVGA G2 Gold+80 650Watts;
RAM:
Motherboard:
- MSI Z97 Gaming 5;
Hard Drive:
- WD Caviar Blue;
Ok so found my CD-Key doesn´t let me do a copy throught microsoft site.
"The product key you entered appears to be for software that was pre-installed on a device.  Please contact the device manufacturer for software recovery options."
So my only option is buying Windows 7 Home Premium.
FX-8370 good work CPU but i7-4790 is better + 390 cause 8GB of VRAM is a good idea for video editing and rendering. :D
And speaking of RAM you should have 16GB of ram! :D
Zen-III-X8-5900X (Gamestation 5)
Case: Medion Micro-ATX Case / Case Fan Front: SUNON MagLev PF70251VX-Q000-S99 70mm / Case Fan Rear: Fanner Tech(Shen Zhen)Co.,LTD. 80mm (Purple) / Controller: Sony Dualshock 4 Wireless (DS4Windows) / Cooler: AMD Near-silent 125w Thermal Solution / CPU: AMD Ryzen 5 3600, 6-cores, 12-threads, 4.2/4.2GHz, 35,3MB cache (T.S.M.C. 7nm FinFET) / CPU: AMD Ryzen 9 5900X, 12(8)-cores, 24(16)-threads, 4.5/4.8GHz, 70.5MB(68,35MB) cache (T.S.M.C. 7nm FinFET) / Display: HP 24" L2445w (64Hz OC) 1920x1200 / GPU: MSI GeForce GTX 970 4GD5 OC "Afterburner" @1450MHz (T.S.M.C. 28nm) / GPU: ASUS Radeon RX 6600 XT DUAL OC RDNA2 32CUs @2.6GHz 10.6 TFLOPS (T.S.M.C. 7nm FinFET) R.ID (NimeZ drivers) / Keyboard: HP KB-0316 PS/2 (Nordic) / Motherboard: ASRock B450M Pro4, Socket-AM4 (SAM enabled) / Mouse: Razer Abyssus 2014 / PCI-E: ASRock USB 3.1/A+C (PCI Express x4) / PSU: EVGA SuperNOVA G2, 550W / RAM A1 & B1: G.SKILL DDR4-3600MHz CL18-20-21-39-60-1T "Samsung 8Gbit C-Die" (2x8GB) / RAM A2 & B2: HyperX DDR4-3600MHz CL16-18-19-37-85-1T "SK Hynix 8Gbit CJR" (2x16GB) / Operating System: Windows 10 Home / Sound 1: Zombee Z500 / Sound 2: Logitech Stereo Speakers S-150 / Storage 1 & 2: Samsung 850 EVO 500GB SSD / Storage 3: Western Digital My Passport 2.5" 2TB HDD / Storage 4: Western Digital Elements Desktop 2TB HDD / Storage 5: Kingston A2000 1TB M.2 NVME SSD / Wi-fi & Bluetooth: ASUS PCE-AC55BT Wireless Adapter (Intel)
 Lake-V-X6-10600 (Gaming PC)
R23 score MC: 9190pts | R23 score SC: 1302pts
R20 score MC: 3529cb | R20 score SC: 506cb
Case: Cooler Master HAF XB Evo Black / Case Fan(s) Front: Noctua NF-A14 ULN 140mm Premium Fans / Case Fan(s) Rear: Corsair Air Series AF120 Quiet Edition (red) / Case Fan(s) Side: Noctua NF-A6x25 FLX 60mm Premium Fan / Controller: Sony Dualshock 4 Wireless (DS4Windows) / Cooler: Cooler Master Hyper 212 Evo / CPU: Intel Core i5-10600(ASUS Performance Enhancement), 6-cores, 12-threads, 4.4/4.8GHz, 13,7MB cache (Intel 14nm++ FinFET) / Display: ASUS 24" LED VN247H (67Hz OC) 1920x1080p / GPU: Gigabyte Radeon RX Vega 56 Gaming OC GCN5 56CUs @1.7GHz 12.19 TFLOPS (Samsung 14nm FinFET) R.ID (NimeZ drivers) / Keyboard: Logitech Desktop K120 (Nordic) / Motherboard: ASUS PRIME B460 PLUS, Socket-LGA1200 (SAM enabled) / Mouse: Razer Abyssus 2014 / PCI-E: ASRock USB 3.1/A+C (PCI Express x4) / PSU: EVGA SuperNOVA G2, 850W / RAM A1 & B1: HyperX DDR4-2666MHz CL13-15-15-30-45-2T "Samsung 8Gbit C-Die" (2x8GB) / RAM A2 & B2: Juhor DDR4-3200MHz CL16-20-20-38-72-2T "SK Hynix 8Gbit MFR" (2x16GB) / Operating System: Windows 10 Home / Sound: Zombee Z300 / Storage 1 & 2: Samsung 850 EVO 500GB SSD / Storage 3: Seagate® Barracuda 2TB HDD / Storage 4: Seagate® Desktop 2TB SSHD / Storage 5: Crucial P1 1000GB M.2 SSD/ Storage 6: Western Digital WD7500BPKX 2.5" HDD / Wi-fi: TP-Link TL-WN851N 11n Wireless Adapter (Qualcomm Atheros)
Vishera-X8-9370 | R20 score MC: 1476cb
Case: Cooler Master HAF XB Evo Black / Case Fan(s) Front: Noctua NF-A14 ULN 140mm Premium Fans / Case Fan(s) Rear: Corsair Air Series AF120 Quiet Edition (red) / Case Fan(s) Side: Noctua NF-A6x25 FLX 60mm Premium Fan / Case Fan VRM: SUNON MagLev KDE1209PTV3 92mm / Controller: Sony Dualshock 4 Wireless (DS4Windows) / Cooler: Cooler Master Hyper 212 Evo / CPU: AMD FX-8370 (Base: @4.4GHz | Turbo: @4.7GHz) Black Edition Eight-Core (Global Foundries 32nm) / Display: ASUS 24" LED VN247H (67Hz OC) 1920x1080p / GPU: MSI GeForce GTX 970 4GD5 OC "Afterburner" @1450MHz (T.S.M.C. 28nm) / GPU: Gigabyte Radeon RX Vega 56 Gaming OC @1501MHz (Samsung 14nm FinFET) / Keyboard: Logitech Desktop K120 (Nordic) / Motherboard: MSI 970 GAMING, Socket-AM3+ / Mouse: Razer Abyssus 2014 / PCI-E: ASRock USB 3.1/A+C (PCI Express x4) / PSU: EVGA SuperNOVA G2, 850W PSU / RAM 1, 2, 3 & 4: Corsair Vengeance DDR3-1866MHz CL8-10-10-28-37-2T (4x4GB) 16.38GB / Operating System 1: Windows 10 Home / Sound: Zombee Z300 / Storage 1: Samsung 850 EVO 500GB SSD (x2) / Storage 2: Seagate® Barracuda 2TB HDD / Storage 3: Seagate® Desktop 2TB SSHD / Wi-fi: TP-Link TL-WN951N 11n Wireless Adapter
Godavari-X4-880K | R20 score MC: 810cb
Case: Medion Micro-ATX Case / Case Fan Front: SUNON MagLev PF70251VX-Q000-S99 70mm / Case Fan Rear: Fanner Tech(Shen Zhen)Co.,LTD. 80mm (Purple) / Controller: Sony Dualshock 4 Wireless (DS4Windows) / Cooler: AMD Near-silent 95w Thermal Solution / Cooler: AMD Near-silent 125w Thermal Solution / CPU: AMD Athlon X4 860K Black Edition Elite Quad-Core (T.S.M.C. 28nm) / CPU: AMD Athlon X4 880K Black Edition Elite Quad-Core (T.S.M.C. 28nm) / Display: HP 19" Flat Panel L1940 (75Hz) 1280x1024 / GPU: EVGA GeForce GTX 960 SuperSC 2GB (T.S.M.C. 28nm) / GPU: MSI GeForce GTX 970 4GD5 OC "Afterburner" @1450MHz (T.S.M.C. 28nm) / Keyboard: HP KB-0316 PS/2 (Nordic) / Motherboard: MSI A78M-E45 V2, Socket-FM2+ / Mouse: Razer Abyssus 2014 / PCI-E: ASRock USB 3.1/A+C (PCI Express x4) / PSU: EVGA SuperNOVA G2, 550W PSU / RAM 1, 2, 3 & 4: SK hynix DDR3-1866MHz CL9-10-11-27-40 (4x4GB) 16.38GB / Operating System 1: Ubuntu Gnome 16.04 LTS (Xenial Xerus) / Operating System 2: Windows 10 Home / Sound 1: Zombee Z500 / Sound 2: Logitech Stereo Speakers S-150 / Storage 1: Samsung 850 EVO 500GB SSD (x2) / Storage 2: Western Digital My Passport 2.5" 2TB HDD / Storage 3: Western Digital Elements Desktop 2TB HDD / Wi-fi: TP-Link TL-WN851N 11n Wireless Adapter
Acer Aspire 7738G custom (changed CPU, GPU & Storage)
CPU: Intel Core 2 Duo P8600, 2-cores, 2-threads, 2.4GHz, 3MB cache (Intel 45nm) / GPU: ATi Radeon HD 4570 515MB DDR2 (T.S.M.C. 55nm) / RAM: DDR2-1066MHz CL7-7-7-20-1T (2x2GB) / Operating System: Windows 10 Home / Storage: Crucial BX500 480GB 3D NAND SATA 2.5" SSD
Complete portable device SoC history:
Apple A4 - Apple iPod touch (4th generation)
Apple A5 - Apple iPod touch (5th generation)
Apple A9 - Apple iPhone 6s Plus
HiSilicon Kirin 810 (T.S.M.C. 7nm) - Huawei P40 Lite / Huawei nova 7i
Mediatek Dimensity 700 (T.S.M.C 7nm) - Cherry Mobile Aqua S10 Pro 5G
Mediatek MT2601 (T.S.M.C 28nm) - TicWatch E
Mediatek MT6580 (T.S.M.C 28nm) - TECNO Spark 2 (1GB RAM)
Mediatek MT6592M (T.S.M.C 28nm) - my|phone my32 (orange)
Mediatek MT6592M (T.S.M.C 28nm) - my|phone my32 (yellow)
Mediatek MT6735 (T.S.M.C 28nm) - HMD Nokia 3 Dual SIM
Mediatek MT6737 (T.S.M.C 28nm) - Cherry Mobile Flare S6
Mediatek MT6739 (T.S.M.C 28nm) - my|phone myX8 (blue)
Mediatek MT6739 (T.S.M.C 28nm) - my|phone myX8 (gold)
Mediatek MT6750 (T.S.M.C 28nm) - honor 6C Pro / honor V9 Play
Mediatek MT6765 (T.S.M.C 12nm) - TECNO Pouvoir 3 Plus
Mediatek MT6797D (T.S.M.C 20nm) - my|phone Brown Tab 1
Qualcomm MSM8926 (T.S.M.C. 28nm) - Microsoft Lumia 640 LTE
Qualcomm MSM8974AA (T.S.M.C. 28nm) - Blackberry Passport
Qualcomm SDM710 (Samsung 10nm) - Oppo Realme 3 Pro
You could get a key from G2A for Windows 8.1, then update to Windows 10. It is £15 at the moment
Seems a really good price and appreciate your time looking for it but wouldn´t benefit me since I would need to get a stronger RAM to accommodate the Windows 8, and I prefer the Windows 7 alot more than the 8.
@Nena360
Well perhaps but their brand new graphic cards and to be honest I prefer to choose something that is more safe to spend even if less 4GB of VRAM, and that was reviewed extensively already, because most of the glitter those new graphic cards have are mostly advertising power AMD created to sell in the spot, that´s why they are selling the Graphic Cards with some time in between.
And about RAM 8GB for my needs will suffice I just want to do soft video editing and rendering so I allocated those extra £40 in something else along with the almost £80 from the i7-4790k/i5-4690k difference, and I prefer more the Intel CPU´s.
And since this build is meant to be crowdfunded with Indiegogo for a personal project I have to consider the other side of the people that can donate to me.
Not always the newest and the most "OMG New Graphics I must haz it" is the best choice, hope you can understand my side. =p
@Nena360
290 with 8GB is probably hard to find now. :P
You said 390 on your first comment not 290 xD
Because the 290 8GB will only be found in used condition. :P
