Hello! I have a FX-6300 OC to 4.3ghz and a GTX 760 SC. I was thinking about upgrading in the Fall, but i don't know what to do. I can go different ways. I can upgrade my FX-6300 to an 8350, keep my FX-6300 and just buy a GTX 970, or i can just switch to Intel (Skylake). The games i mostly play are League of Legends, WoW, Borderlands 2, and H1Z1. I want to take advantage of the new games coming out like MGS5, Fallout 4, Rainbow Six Siege and other games. Money is not an issue, but i do want more for the money i'm going to be spending. Help me out here guys. Thanks
CPU- FX6300 4.3ghz
Mobo- Asus M5A97 R2.0
PSU- Corsair CX600
RAM- Corsair Vengeance 8GB
HDD- WD 1TB
OS- Windows 8.1
GPU- GTX 760 SC
https://linustechtips.com/topic/394578-upgrade-option-help/
CPU- FX6300 4.3ghz
PSU- Corsair CX600
HDD- WD 1TB
OS- Windows 8.1
GPU- GTX 760 SC
Do not go AMD for an upgrade.
Intel Core i7-6700K | Corsair H105 | Asus Z170I PRO GAMING | G.Skill TridentZ Series 16GB | 950 PRO 512GB M.2
Asus GeForce GTX 980 Ti 6GB STRIX OC | BitFenix Prodigy (Black/Red) | XFX PRO Black Edition 850W
My BuildPCPartPicker | CoC
https://linustechtips.com/topic/394578-upgrade-option-help/#findComment-5324197
CPU- FX6300 4.3ghz
PSU- Corsair CX600
HDD- WD 1TB
OS- Windows 8.1
GPU- GTX 760 SC
 Sure you can switch to Skylake but it would probably be expensive at launch and many months after probably. If you are on a budget you can get a i5-4590 paired with a B85 motherboard. :) It would give you better perfomance in H1Z1 plus you could play the latest games with it and it will last a long time for the foreseeable future. ^_^
Echelon Mk 2.11
  • Processor: Intel Core i5-6500
  • Cooler: Cryorig H7 (With a 120 mm Thermaltake Riing RGB)
  • Motherboard: MSI B150M Bazooka Plus
  • Memory: 16 (2x8) GB DDR4 Kingston HyperX Fury (Black)
  • Video Card: Sapphire NITRO R9 390 (Stock)
  • Storage:  1 TB Western Digital Blue
  • Power Supply: 520 W Seasonic M12II Evo (with custom extensions and cable combs)
  • Casing: NZXT S340 Elite (Matte Black)
  • Fans: 2x 120 mm & 3x 140 mm Thermaltake Riing RGB
  • Display: 22 " LG Flatron L227WTG-PF LCD (OCed to 76 Hz)
  • Keyboard: Logitech K120
  • Mouse: Logitech G402 Hyperion Fury
  • Mousepad: SteelSeries QcK
  • Operating System: Windows 10 Pro (64-bit)
https://linustechtips.com/topic/394578-upgrade-option-help/#findComment-5325673
