Can somebody help me with upgrading my pc, like say parts that i should upgrade. total budget that i have is around 400 euro.
Pc Specs:
CPU : AMD FX-4100 @ 3.6 GHz
GPU : Gigabyte HD 7750
Motherboard : Gigabyte GA-970A-DS3
RAM : 1 Stick of 4 gb Kingston HyperX Blu.
STORAGE : WD BLUE 1 TB HardDrive
Cpu has a Cooler Master Heatsink of some sort and a stock cooler.
Pls help make it so i would be able to play some of the newer games at nice graphics
https://linustechtips.com/topic/394540-help-me-upgrade-my-pc/
http://pcpartpicker.com/p/C69VQ7 That's what I would do assuming your psu can handle it. You could change out the mobo to fit your color scheme etc.
https://linustechtips.com/topic/394540-help-me-upgrade-my-pc/#findComment-5323757
https://linustechtips.com/topic/394540-help-me-upgrade-my-pc/#findComment-5324158
