mini ITX or micro ATX?
What cpu/case/color scheme/ports do you have/want/need? Do you want onboard wifi? What's your budget?
PSU Tier List | CoC
Gaming Build | FreeNAS Server
https://linustechtips.com/topic/394516-mini-atx-motherboard/#findComment-5323398
Micro ATX please, case (in there), color (preferably white please) This is my current build, http://uk.pcpartpicker.com/p/BjMjkL
Budget Around £800 if you're american please don't convert if as the prices are so much more expensive here so say the figure in dollars and it's probably the same or close in pounds.
https://linustechtips.com/topic/394516-mini-atx-motherboard/#findComment-5323520
This is my current build, http://uk.pcpartpicker.com/p/BjMjkL.
Have you already purchased the parts? Keep in mind, there are no black/white mATX boards.
I opt'd for a Z87 board since it's the one that will match your white color scheme the best, and I swapped out the V300 which has been a terrible SSD ever since Kingston swapped out the NAND chips for cheap garbage.
CPU: Intel Core i5-4690K 3.5GHz Quad-Core Processor  (£178.00 @ Amazon UK)
Motherboard: ASRock Z87M Extreme4 Micro ATX LGA1150 Motherboard  (£100.83 @ Amazon UK)
Storage: Samsung 850 EVO-Series 120GB 2.5" Solid State Drive  (£48.26 @ Amazon UK)
Video Card: Zotac GeForce GTX 970 4GB Video Card  (£243.17 @ More Computers)
Case: Corsair Air 240 MicroATX Mid Tower Case  (£69.83 @ Scan.co.uk)
Power Supply: XFX XTR 750W 80+ Gold Certified Fully-Modular ATX Power Supply  (£86.84 @ More Computers)
Total: £797.00
Generated by PCPartPicker 2015-06-26 19:49 BST+0100
PSU Tier List | CoC
https://linustechtips.com/topic/394516-mini-atx-motherboard/#findComment-5323522
Total: £797.00
Thanks, yeah I agree but it'll do very little just booting windows to be honest. Also is there a power supply that you know of that is white?
https://linustechtips.com/topic/394516-mini-atx-motherboard/#findComment-5323608
The v300 is still an inferior ssd, if the money really matters, then check out an adata sp600/620 as its only like a dollar or two more than a v300.
Ocz, nzxt, and fractal have white psus, but none are priced particularly well.
PSU Tier List | CoC
https://linustechtips.com/topic/394516-mini-atx-motherboard/#findComment-5323664
Thanks mate you have a been a very big help, all likes :)
https://linustechtips.com/topic/394516-mini-atx-motherboard/#findComment-5323980
