What games are you going to be playing? (assuming you're gaming)
The G3258 is only the ideal choice if you're intention is to play games that only run on one or two cores (and if you don't want to do any real multitasking) otherwise an i3 would be well worth the extra money, and if you can't afford an i3, then an 860k would suffice.
PSU Tier List | CoC
Gaming Build | FreeNAS Server
https://linustechtips.com/topic/394468-help/#findComment-5322693
@Shockers8710
Much better for the price.
EDIT: Also, quote us to see your responses. And follow your topics.
Motherboard: MSI H81M-P33 Micro ATX LGA1150 Motherboard  ($54.95 @ Vuugo)
Memory: Corsair 8GB (1 x 8GB) DDR3-1600 Memory  ($59.99 @ Memory Express)
Video Card: Sapphire Radeon R9 280X 3GB Tri-X Toxic Video Card  ($279.05 @ Vuugo)
Power Supply: EVGA 500W 80+ Certified ATX Power Supply  ($35.99 @ NCIX)
Total: $686.47
Generated by PCPartPicker 2015-06-26 13:04 EDT-0400
https://linustechtips.com/topic/394468-help/#findComment-5322710
Yes I am gaming probably h1z1 csgo and twd. Maybe the new battlefront
Storage: Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive  ($56.98 @ DirectCanada)
Power Supply: EVGA 500W 80+ Bronze Certified ATX Power Supply  ($64.98 @ DirectCanada)
Total: $701.89
Generated by PCPartPicker 2015-06-26 13:05 EDT-0400
PSU Tier List | CoC
https://linustechtips.com/topic/394468-help/#findComment-5322713
Total: $701.89
@Shockers8710
Total: $686.47
i have an external 2tb drive so id switch it out for an ssd plus I'm not quite sold on the 280x isn't the same as the 960 in 1080p gaming?
https://linustechtips.com/topic/394468-help/#findComment-5322741
I have an 2tb external drive so id change out the hdd for an ssd and I'm not quite sold on the 280x isn't it the pretty much same as an 960 in 1080p gaming?
280X Is generally better than the 960 + More VRAM
i7 8086k @ 5.3Ghz / 32GB DDR4 Trident Z RGB @ 3733Mhz / Aorus GTX 1080 11Gbps / PG348Q
https://linustechtips.com/topic/394468-help/#findComment-5322746
No, the 960 struggles to get 60fps in some games even on 1080p, the 280x will max out everything on 1080p.
https://linustechtips.com/topic/394468-help/#findComment-5322750
A 280x is still faster, plus gives you extra VRAM should it become necessary.
For an SSD, don't get a V300 since it's pretty bad ever since Kingston swapped out the hardware for cheap crap. Go with this instead: http://ca.pcpartpicker.com/part/a-data-internal-hard-drive-asp600s3128gmc
PSU Tier List | CoC
https://linustechtips.com/topic/394468-help/#findComment-5322752
the 280x is way more expensive though the least expensive name-brand was 300$+ but i disabled every store but newegg ncix cc and amazon because i trust them.
https://linustechtips.com/topic/394468-help/#findComment-5322784
These stores wouldn't be on PCPP if they weren't trusted.
https://linustechtips.com/topic/394468-help/#findComment-5322793
im not an nvidia fan boy but i prefer them plus for the extra cost of an 280x for 5-8 frames its not worth it.
https://linustechtips.com/topic/394468-help/#findComment-5322868
fx6300 or i3 which is better for gaming?
https://linustechtips.com/topic/394468-help/#findComment-5322908
Get w/e you prefer, but that 2gb limit is gonna wreck you hard. 2GBs are slowly becoming obsolete for GPUs nowadays.
https://linustechtips.com/topic/394468-help/#findComment-5322909
then why can't i just oc the pentium then to 4.7? Have you seen the benchmarks?
The i3 has Hyperthreading which makes it better than the Pentium K. Hyperthreading makes the i3 a semi-quadcore. The Pentium has started to fall behind recently.
https://linustechtips.com/topic/394468-help/#findComment-5322987
