Bottle neck help/ What should i upgrade next
Solved by Soulsie,
what games?
GTA 5 and such
Yeah that would be your cpu bottlenecking the 970.
Well reinstalling Windows might make a difference. But if you want to take more advantage of the 970 and you really have an upgrade itch, then I suggest a CPU and motherboard upgrade.
AMD CPU's are not ideal for heavy gaming, upgrade that to a good i5 (or i7 if you need HyperThreading).
Noted.
What CPU would ya'll suggest for a decent price, that can handle gta 5 in nice graphics.
Anyhow, thanks for the answers
