I'm looking for a decent psu that's 600-700w around the 70-110 budget around.
I came across this:
http://ca.pcpartpicker.com/part/antec-power-supply-ea650platinum
I'm just wondering how reliable antec psu are, and also looking for suggestions and recommendations.
Thank you in advance :)
https://linustechtips.com/topic/394198-psu-help/
It's good but not great. Antec psus are generally solid but the linked psu isn't amazing despite the platinum rating.
It would help to list what your plan to power.
Moved to Cases and Power Supplies.
https://linustechtips.com/topic/394198-psu-help/#findComment-5319082
I don't really like Antec PSU's imo. Get something like EVGA or Corsair
01101110 01101111 00100000 01101111 01101110 01100101 00100000 01101100 01101111 01110110 01100101 01110011 00100000 01111001 01101111 01110101
Main Rig: i7-4790K | Corsair H100i | Asus Z97 | 16GB Ripjaws | 4TB WD Black/512GB SSD | x2 R9 290x | NZXT H440 | HX1000i | 6 Noctuas   [spoiler=SILENT BUILD] Silent build: i5-4460, Be Quiet! Pure Rock, Asrock H97, 8GB HyperX, Samsung 850 Evo 500gb, MSI GTX 970, Be Quiet! Silent Base 800, EVGA Supernova GS 650w
AMD CPU's. [spoiler=] thats right m8 get 420 no scoped
https://linustechtips.com/topic/394198-psu-help/#findComment-5319087
I came across this:
No. EarthWatts Platinum are only good for efficiency and nothing else. Voltage regulation and ripple suppression are actually quite awful.
Look at something like the EVGA 650GS or 750B2 instead.
"Rawr XD"
https://linustechtips.com/topic/394198-psu-help/#findComment-5321981
That is not how that works.... Neither of those brands actually manufacture their own PSUs. Antec usually goes to Seasonic or Delta for OEMs and both are superb. Many Antec PSUs are amazing. EVGA doesn't make the PSUs either - they usually go to Seasonic and Superflower, at least for their high-end units like the B2 and up and the GS series. Corsair doesn't make PSUs as well. The only things decent from them these days are the older AXs which were made by Seasonic and the new RMi which is actually quite amazing. Most Corsair PSUs are actually wildly overpriced for what you get.
https://linustechtips.com/topic/394198-psu-help/#findComment-5322026
This, but the Earthwatts Platinum is unfortunately is made by FSP, which means epic efficiency, but pretty meh performance everywhere else.
 http://www.techpowerup.com/reviews/Antec/EA-650_Platinum/
http://www.hardwaresecrets.com/antec-earthwatts-platinum-650-w-power-supply-review/
"Rawr XD"
https://linustechtips.com/topic/394198-psu-help/#findComment-5322142
I was generalizing most Antec PSUs. For the most part they have great stuff.
https://linustechtips.com/topic/394198-psu-help/#findComment-5322162
I came across this:
http://www.jonnyguru.com/modules.php?name=NDReviews&op=Story6&reid=429
Check Johnny Guru, best site for PSUs reviews, i can't tell you exactly what to get, depends on availability, prize on your region, and in the end, what you think is good for you. But as long as you get informed and get a unit that a site like johnny guru says it's good, you can have peace of mind that you are getting a good PSU. I linked one i think it's very good based on my own personal experience (I have the 850W version)
System
  • CPU
    I7-4790K @ 4,7GHz
  • Motherboard
    Asus MAXIMUS Formula VI
  • RAM
    Kingston HyperX FURY 16GB Kit (2x8GB) 1866MHz
  • GPU
    MSI GTX 1070 Gaming X
  • Case
    Cooler Master Cosmos SE
  • Storage
    Samsung 840 EVO 500GB+WD Green 3TB
  • PSU
    EVGA SuperNOVA 850G2 80PLUS Gold Certified
  • Display(s)
    ASUS PB277Q 27" WQHD 2560x1440 75Hz 1ms
  • Cooling
    Corsair H105 with AP121s and Phanteks fans
  • Keyboard
    Logitech G610 Orion
  • Mouse
    E-3lue E-Blue Mazer II 2500 DPI Blue LED 2.4GHz Wireless Optical Gaming Mouse
  • Sound
    Audio-Technica ATH-M20x
  • Operating System
    Windows 10
https://linustechtips.com/topic/394198-psu-help/#findComment-5322460
Honestly the huge price increase from the GS to the G2 isn't worth it.
"Rawr XD"
https://linustechtips.com/topic/394198-psu-help/#findComment-5323340
8 dollars is huge?
System
  • CPU
    I7-4790K @ 4,7GHz
  • Motherboard
  • RAM
  • GPU
  • Case
  • Storage
  • PSU
  • Display(s)
  • Cooling
  • Keyboard
    Logitech G610 Orion
  • Mouse
  • Sound
  • Operating System
    Windows 10
https://linustechtips.com/topic/394198-psu-help/#findComment-5324159
Anyway, just saying, anything 80+ gold from EVGA should be great, i got mine on black friday for 108$ (850 watts) so maybe i don't consider price that much but all options stay within his price point, i just happen to have personal experience with the G2 850W and its awesome.
System
  • CPU
    I7-4790K @ 4,7GHz
  • Motherboard
  • RAM
  • GPU
  • Case
  • Storage
  • PSU
  • Display(s)
  • Cooling
  • Keyboard
    Logitech G610 Orion
  • Mouse
  • Sound
  • Operating System
    Windows 10
https://linustechtips.com/topic/394198-psu-help/#findComment-5324182
Oh, i don't count rebates, if he is willing to do one, yeah, right now he can get a discount, but, personally not a fan
System
  • CPU
    I7-4790K @ 4,7GHz
  • Motherboard
  • RAM
  • GPU
  • Case
  • Storage
  • PSU
  • Display(s)
  • Cooling
  • Keyboard
    Logitech G610 Orion
  • Mouse
  • Sound
  • Operating System
    Windows 10
https://linustechtips.com/topic/394198-psu-help/#findComment-5325762
