Does anyone have an idea of how to air cool my router? It gets really hot and I feel like that's the cause of it randomly slowing down....
I was thinking of somehow strapping a case fan to the bottom. Not sure how i'd power it though
Desktop: The Bluez | CPU: i5-3570k @ 4.5 ghz 1.296V | CPU Cooler: Hyper 212 Evo | Motherboard: P8Z77 M-Pro | Memory: 16 GB 1600Mhz Kingston HyperX
GPU: Asus GTX 780ti DirectCu II | HDD: Some Random Hitachi 1TB, WD Blue 1TB, 850 EVO 500GB | PSU: Rosewill Hive 750W | Case: Enermax Ostrog GT (Blue Ver.)
Laptop: Razer Blade 14 2013 256GB
https://linustechtips.com/topic/393924-air-cooling-router/
http://linustechtips.com/main/topic/382249-router-overheating/
I posted a picture of how I did it to mine on here but I cant find the pic on my computer.  I found the cable in one of those usb powered laptop coolers but you could rig something up
edit: scroll down, mine is the picture of the fan NOT the watercooler haha
LTT Community Standards                                               Welcome!-A quick guide for new members to LTT
Man's Machine- i7-7700k@5.0GHz / Asus M8H / GTX 1080Ti / 4x4gb Gskill 3000 CL15  / Custom loop / 240gb Intel SSD / 3tb HDD / Corsair RM1000x / Dell S2716DG
The Lady's Rig- G3258@4.4GHz(1.39v) on Hyper 212 / Gigabyte GA-B85M / gtx750 / 8gb PNY xlr8 / 500gb seagate HDD / CS 450M / Asus PB277Q
https://linustechtips.com/topic/393924-air-cooling-router/#findComment-5315930
LOL the watercooled one. Anyway thanks! I'll look around for a similar adapter
https://linustechtips.com/topic/393924-air-cooling-router/#findComment-5315958
Normaly they don't overheat. Are you sure no vent slot is covered by something? Also try to place the router in a way that there are vent slots on the "bottom" side and the "top" side to increase natural convection.
Mineral oil and 40 kg aluminium heat sinks are a perfect combination: 73 cores and a Titan X, Twenty Thousand Leagues Under the Oil
https://linustechtips.com/topic/393924-air-cooling-router/#findComment-5319381
Getting cheap laptop cooler pad will be the easiest and most space demanding solution. There are adapters for DC to fan power/molex/sata. That is the other option. Wouldn't get usb->fan adapter as it won't be powerful enough.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
https://linustechtips.com/topic/393924-air-cooling-router/#findComment-5320150
5v is plenty to cool a router with most fans. I wouldnt use more than that because then youre just making excessive noise. Does not take much to cool that tiny box
https://linustechtips.com/topic/393924-air-cooling-router/#findComment-5320269
