I'm trying to hunt down a evga gtx 680 classified water block, anyone know where i can get them?
Project Casper - Glass Tubing Build
Ryzen 9 5905x     |    Gigabyte Aorus Extreme X570    |   Strix 3090
GSkill 64gb 4000mhz   |    EVGA 1600T psu     |      3x Samsung 980 Pro NVME 1tb Raid 0
  4 x Crucial MX500 2tb raid 0   |    Glass Hard Line Tubing  - EKWB Blocks
https://linustechtips.com/topic/39385-680-classified-water-block/
Have you tried coolingconfigurator.com?
Yes, no blocks can work with it since its a custom pcb and its extended. I really dont want to use an unervisal block.
https://linustechtips.com/topic/39385-680-classified-water-block/#findComment-507870
Then you won't be able to watercool your GPU.
https://linustechtips.com/topic/39385-680-classified-water-block/#findComment-508021
