Raid 1 Array help
Solved by Captain_WD,
If i already have a 1 tb drive with data on it, can i add a second one and set up a Raid 1 array without losing any data.
Hey dfish292,
If you are using the on-board RAID controller, the drives in the RAID array will be formatted and the data will be lost. Some dedicated RAID cards have the option to configure the Mirroring mode so that one of the drives is restored onto the other one and then get formatted so I'd look into that.
I'd follow my fellow captain's advice as RAID is not a backup and having one is recommended. Get everything on another drive, configure your RAID and then restore the data there.
Captain_WD.
