well i need some help to find out what my k70 is doing. the issue is that as i type in any program form games to chrome to word it will do a double type any key with only one key press like (ee rr ll ff) so on and so on and it random to.  now ii do not know what i must have done to have it do that but even as i type this i have to go back and fix all the typos please help me really do not have the cash to get a new keyboard
thanks
https://linustechtips.com/topic/393382-corsair-k70-help/
Is your K70 the RGB variant? or the non-RGB? Does it only happen with specific key/s? or more like random? Make sure that you are using the latest version of the software and the KB has the latest Firmware. You can get the latest driver here, http://www.corsair.com/en-us/support/downloads
If its the RGB version, what I would try is, I'd flash the KB's FW through the SW (CUE) and see if that changers anything. I would also try in on a different system (if possible) just to see if the problem will follow and to make sure its not system related.
https://linustechtips.com/topic/393382-corsair-k70-help/#findComment-5371425
