Weird Audio Problem
Go to solution Solved by Rheinwasser,
Any other browser doing that?
sorry, i was busy. i found the solution.
the problem is windows. every time it expects a mic input in silences the audio output by up to 80%.
you can disable this under control panel -> hardware and sound -> sound -> communication
source: http://superuser.com/questions/74116/windows-7-lowers-applications-volume-automatically
When I open a new tab on my laptop in chrome the audio gets noticeably quieter and the sound turns tinny. If I switch back to another tab it does away. It doesnt matter which programme is the audio source.
I have no idea what could possibly cause this.
Any help is appreciated.
https://linustechtips.com/topic/392469-weird-audio-problem/
https://linustechtips.com/topic/392469-weird-audio-problem/#findComment-5321890
