Hey boys and girls, I got myself a pc recently and I saw that the gpu doesn fit in the motherboard if the giant fan is there, Its not really a fan, more like a plastic thingi with a heatsink in it. So the problem is that the plastic thingi covers some part of the gpu. My question is that if I can take out the plastic thingi and put the heatsink there only, is it possible?? Btw the fan is not attached to the plastic.
https://linustechtips.com/topic/392270-cpu-without-fan/
can you post a picture for some clarification, also follow your own topic so you will see all of the replys
#killedmywife #howtomakebombs #vgamasterrace
https://linustechtips.com/topic/392270-cpu-without-fan/#findComment-5293960
pics or it didnt happen ! :D
You're gonna need to post pictures because I personally have no idea what you're talking about.
please show us pics this sounds so false
Probably talking about the inside of an HP or Dell office computer
They have OEM air cooler thingies with green plastic parts all over the place
https://linustechtips.com/topic/392270-cpu-without-fan/#findComment-5294022
but those shouldn't cover the pcie slots...
https://linustechtips.com/topic/392270-cpu-without-fan/#findComment-5294029
if its like that, dont take off the plastic thing, because it;s meant to direct the air over the heatsink. if you do, temps will be awful if the pc doesn't outright overheat.
FairladyZ | If you want to reply to me, please quote my post! Idiocity, the best money wasting PC build ever!
https://linustechtips.com/topic/392270-cpu-without-fan/#findComment-5294049
first of all boys and girls? really? :P
Sounds like you are talking about a shroud. Yeah, you can take it off, but check how it effects temps.
Edit: or not if it is that green thing @Generallee posted. I was talking about the ones that go to the side panel and are a bit more basic.
Intel 4790k | Asus Z97 Maximus VII Impact | Corsair Vengeance Pro Series 16 GB 1866Mhz | Asus Strix GTX 980 | CoolerMaster G550 |Samsung Evo 250GB | Synology DS215j (NAS) | Logitech G502 |
https://linustechtips.com/topic/392270-cpu-without-fan/#findComment-5294052
A Dell Optiplex overheating, then ultimately busting a cap on the motherboard, you're then greeted with a Boeing engine slowly throttling to full speed until your parents bust the door wondering what the hell is happening. Memories.
https://linustechtips.com/topic/392270-cpu-without-fan/#findComment-5294079
there you go
if the heatsink underneath the plastic is not in the way you could just cut the plastic, but leave as much of it intact because the heatsink needs it to direct airflow
https://linustechtips.com/topic/392270-cpu-without-fan/#findComment-5294393
I wont remive the heatsink, only the plastic thibg tjat covers it.
Removing that is a terrible idea, because if you do, then the fan will be blowing air in the case, but less of it will be able to take heat away from the heatsink, and that tower probably is a newer office optiplex with the Core series processors, they will overheat very quickly if you don't leave that thing on.
https://linustechtips.com/topic/392270-cpu-without-fan/#findComment-5337593
So this is one of Dells BTX systems. BTX first of all uses different mounting holes for the cpu cooler than standard LGA 775 so a new cpu cooler is out of the question. Also only single slot cards will work unless modded to fit (I assume you already know this :D) I would say your best bet is removing part of the plastic just enough so your card fits in.
Example: Remove part I highlighted in red with a saw or whatever you can get your hand on, if your card is any longer then remove the part highlighted in blue.
Hope this helped and glad to see your still getting use out of your BTX system :D
A shadowy flight into the dangerous world of a man who does not exist.
Core 4 Quad Not Extreme, only available on LGA 557 at your local Circuit City
https://linustechtips.com/topic/392270-cpu-without-fan/#findComment-5337647
So this is one of Dells BTX systems. BTX first of all uses different mounting holes for the cpu cooler than standard LGA 775 so a new cpu cooler is out of the question....
I concur, you are very likely to be SOL for sourcing an after market cooler.
If you do attempt his hacksaw suggestion be prepared for very bad things to happen.
The single biggest problem in communication is the illusion that it has taken place.
https://linustechtips.com/topic/392270-cpu-without-fan/#findComment-5337718
