i finaly did my water loop and wondering is 42c runnig prime 95 stress test mode on a maximus v formula with a 3770k where it should be. it hovers around 42-44 one and a blue moon it hits 50 is it suposed to fluxuate like that or stay a constant temp.
im using the ek l360 kit but i changed to a apogee hd cpu block and used  primochills blood red tubing as i sisnt like the black rubber look and i changed to those danger denn fittings using some special rench they look nicer(thank you microcenter for saying u have every thing i need instock on yourwebsite only to drive 45 min to find out you aint got 3/4 of the sh*t i need)
i have 3 fans blowing up 2 120 mml fans on side and 240mm in front(cosmos ii case)
https://linustechtips.com/topic/39186-water-cooling-temps/
I would disagree with CoolBeans. Technically that is right, but you want your temps to be appropriate to your frequency and voltage. However, those temps look very fine. No need to worry.
https://linustechtips.com/topic/39186-water-cooling-temps/#findComment-504760
