Hi im going to be bulding this build with:
PCPartPicker part list: http://pcpartpicker.com/p/mYDdTW
Price breakdown by merchant: http://pcpartpicker.com/p/mYDdTW/by_merchant/
CPU: Intel Core i7-4790K 4.0GHz Quad-Core Processor  ($328.99 @ SuperBiiz)
CPU Cooler: Fractal Design Kelvin T12 62.4 CFM Liquid CPU Cooler
Motherboard: Asus MAXIMUS VII IMPACT Mini ITX LGA1150 Motherboard  ($218.99 @ SuperBiiz)
Memory: Corsair Vengeance 16GB (2 x 8GB) DDR3-1600 Memory  ($106.99 @ Newegg)
Storage: Samsung 850 EVO-Series 500GB 2.5" Solid State Drive  ($177.89 @ OutletPC)
Storage: Western Digital BLACK SERIES 1TB 3.5" 7200RPM Internal Hard Drive  ($70.99 @ Newegg)
Video Card: NVIDIA GeForce GTX 970 4GB Video Card  ($329.99 @ Best Buy)
Case: Fractal Design Node 304 (White) Mini ITX Tower Case  ($64.99 @ NCIX US)
Power Supply: Silverstone Strider Gold 450W 80+ Gold Certified Fully-Modular SFX Power Supply  ($88.98 @ Newegg)
Operating System: Microsoft Windows 8.1 OEM (64-bit)  ($86.98 @ OutletPC)
Monitor: Acer S220HQLAbd 60Hz 21.5" Monitor  ($99.99 @ Amazon)
Total: $1574.78
Generated by PCPartPicker 2015-06-22 10:44 EDT-0400
I already have the reference gtx 970 on hand but it says the minimal power requirements is 500w but pcpartpicker calculated that my whole system only needed 321w, so i dont know what wattage i should use.
https://linustechtips.com/topic/391670-enough-power/
Total: $1574.78
450 doesn't give much room to grow.
Intel Core i7-6700K | Corsair H105 | Asus Z170I PRO GAMING | G.Skill TridentZ Series 16GB | 950 PRO 512GB M.2
Asus GeForce GTX 980 Ti 6GB STRIX OC | BitFenix Prodigy (Black/Red) | XFX PRO Black Edition 850W
My BuildPCPartPicker | CoC
https://linustechtips.com/topic/391670-enough-power/#findComment-5286259
get a 550 watt it will be fine.
Gpu: MSI 4G GTX 970 | Cpu: i5 4690k @4.6Ghz 1.23v | Cpu Cooler: Cryorig r1 ultimate | Ram: 1600mhz 2x8Gb corsair vengeance | Storage: sandisk ultra ii 128gb (os) 1TB WD Green | Psu: evga supernova g1 650watt | Case: fractal define s windowed |
https://linustechtips.com/topic/391670-enough-power/#findComment-5286273
get a 650w priced similar
"Sulit" (adj.) something that is worth it
i7 8700K 4.8Ghz delidded / Corsair H100i V2 / Asus Strix Z370-F / G.Skill Trident Z RGB 16GB 3200 / EVGA GTX 1080Ti FTW3 / ASUS ROG SWIFT PG279Q
Samsung 850 EVO 500GB & 250GB - Crucial MX300 M.2 525GB / Fractal Design Define S / Corsair K70 MX Reds / Logitech G502 / Beyerdynamic DT770 250Ohm
SMSL SD793II AMP/DAC - Schiit Magni 3 / PCPP
Old Rig
i5 2500k 4.5Ghz | Gigabyte Z68XP-UD3P | Zotac GTX 980 AMP! Extreme | Crucial Ballistix Tactical 16GB 1866MHz
https://linustechtips.com/topic/391670-enough-power/#findComment-5286276
