It'd be nice if you actually listed the temps.
https://linustechtips.com/topic/39162-is-aisuite-2-temps-correct/#findComment-504322
Try and use another program to check such as speedfan (my personal favorite) core temp and other such things will do fine too but beware core temp is known to cause bsods i personally experienced this and had to uninstall it.
My rig: Case: Corsair 760T CPU: Intel 4690k MOBO: MSI Z79 Gaming 5 RaM: 16gb HyperX SSD: 256gb Samsung pro HDD: 1tb Toshiba PSU: Thermaltake smart 750 GPU: 1x GTX 1080 Founders edition
https://linustechtips.com/topic/39162-is-aisuite-2-temps-correct/#findComment-504323
yeah i had that happen with core temp a few time
I did a thing once and it was awsome: https://soundcloud.com/jamese666/junkhead-cover-with-vocals
https://linustechtips.com/topic/39162-is-aisuite-2-temps-correct/#findComment-504329
Your temps look fine.
https://linustechtips.com/topic/39162-is-aisuite-2-temps-correct/#findComment-504340
Do you have Prime 95 on your computer?
https://linustechtips.com/topic/39162-is-aisuite-2-temps-correct/#findComment-504374
Would anybody mind explaining what vcore is? I thought that was just the voltage applied to your CPU? Why would that have a temp????
https://linustechtips.com/topic/39162-is-aisuite-2-temps-correct/#findComment-504428
It's most likely the components supplying the voltage to the CPU.
https://linustechtips.com/topic/39162-is-aisuite-2-temps-correct/#findComment-504535
Is this a new occurrence? How were the temperatures when it was first built?
-Corsair 750D - MSI Mpower Z77 - 3570k @ 4.21 -Corsair H60- 8GB Corsair Vengeance 2133 Mhz- Corsair RM850 - MSI 780 Lightning -256GB SSD- 2 1TB HDDs - LG 23' Flatron - Razer Death Adder - Ducky Shine 3 Cherry MX Blue - Logitech z506 5.1-
Project - Bloody Lightning
https://linustechtips.com/topic/39162-is-aisuite-2-temps-correct/#findComment-504879
This is the first time I'm hearing of "vcore temps". :/
First time for everything!
post-30437-0-11377100-1374719904_thumb.p
https://linustechtips.com/topic/39162-is-aisuite-2-temps-correct/#findComment-505098
Here are mine for comaprison. 72 degrees farenheit ambient. DotA 2 and web browsing.
post-5090-0-97000400-1374722277_thumb.pn
| NCASE M1 | ASUS ROG Strix Z270I | Intel Core i7-7770k | ASUS GTX 1070 ROG STRIX | SilverStone SFX600W | Crucial Ballistix Sport 16GB | Corsair H100i v2 | Samsung 960 EVO 500GB | Crucial MX300 525GB |
https://linustechtips.com/topic/39162-is-aisuite-2-temps-correct/#findComment-505255
