I don't think there is any red mini itx motherboards for z77. the first one I've seen is the rog impact but that is z87
i9 25.6 GHz with NeuronThreading, 256gb 6000 MHz RAM, GTX 990 OC 3024MHz 12gb, Skeletal X99 motherboard, 1 Petabyte SSD, Fractal Design Humaniod R1 Case, Herbivore 10,000W PSU, Noctua NF16 LP Derma Cooler.
Probably the only Star Citizen player who is planning on a career in Journalism instead of piracy, mining, trading, exploration, military, station management, etc.
Generation 0: The first time you see this add 1 to the number and copy it into your sig. Consider it a social experiment.
https://linustechtips.com/topic/39160-red-mini-itx-motherboard/#findComment-504270
I would actually switch over to z87 for that
well it isn't out yet. (should be released early august) But from what I've seen in previews it is the best mini itx board money can buy. If you can wait I would definitely go for that.
https://linustechtips.com/topic/39160-red-mini-itx-motherboard/#findComment-504304
How much do you think itll be
"My Profile Picture Says Everything You Need To Know About Life"
https://linustechtips.com/topic/39160-red-mini-itx-motherboard/#findComment-504353
I want to say around $250-300
https://linustechtips.com/topic/39160-red-mini-itx-motherboard/#findComment-504361
Make that $150-200 .. The hero board isn't even priced that high let alone the mini ITX.
The mainstream mini itx board is $185. Rog boards are usually more expensive than the mainstream boards
https://linustechtips.com/topic/39160-red-mini-itx-motherboard/#findComment-504755
In this link, it says the board is $39... I dont know if the link was in australian currency or what but if it was itll still be pretty expensive.. $365.. and from other sources I found that the ROG impact was priced 1.499 kr on a danish site called Dustinhome.dk. I tried converting the currency and it didnt work. so I just looked around for prices near 1.499 and found the GTX 660 Ti so I'm guessing it might be $250.
I would buy the Impact if it was $250, I don't think I wanna spend $300-$400 on a mITX board. Thats just crazy.
https://linustechtips.com/topic/39160-red-mini-itx-motherboard/#findComment-509123
Yeah, according to google 1499 danish krone comes to about $266 USD. To me $250 would be very reasonable considering what you get and considering the price of their next mITX board down, $300 or more seems like to big of a jump in price point and would be pretty risky to price it that high I mean we know people will pay that much for ATX boards but i'm not sure they would for mITX.
https://linustechtips.com/topic/39160-red-mini-itx-motherboard/#findComment-509943
Evga has a killer one. Although I think it may only be for 1150
My Rig: AMD FX-8350 @ 4.5 Ghz, Corsair H100i, Gigabyte gtx 770 4gb, 8 gb Patriot Viper 2133 mhz, Corsair C70 (Black), EVGA Supernova 750g Modular PSU, Gigabyte GA-990FXA-UD3 motherboard, Asus next gen wifi card.
https://linustechtips.com/topic/39160-red-mini-itx-motherboard/#findComment-511570
