I recently got the ASUS VG248QE and returned due to frustratingly poor color reproduction but I greatly miss the 144hz. I was wondering then whether or not the Acer XB240H would have slightly better color reproduction or is there an even better TN panel that looks alot better then the ASUS panel? I can't afford the $700-$800 IPS 144hz panels either or I would just pick up a swift.
https://linustechtips.com/topic/391047-tn-panel-question/
AFAIK the VG248QE only suffers because we cant adjust the gamma think (that i honestly dont understand)
The BenQ 2411Z can be adjusted (as far as I know, but still TN), maybe give it a try?
There is something about colors going weird when going from 60hz to 144hz, but on the benQ you can adjust it (from what I have heard) and is the reason for why people pick it over the 248qe
CPU: I7 4790K(4.6@1.252v)                               Case: Fractal Design Define R5 Windowed(Black)           Cooler: CM 212 EVO + NF F12 iPPC
RAM: HyperX Fury 1600MHZ CL10 2x4GB      Storage: Samsung 850 EVO(250GB) + WD Red(2TB)      PSU: Corsair RM750 (and no, it hasn't blown up!)
MoBo: Asus Maximus VII Ranger                      Graphics: MSI GTX 970 TwinFrozr (1494MHZ Core)       OS: Windows 10 Enterprise
https://linustechtips.com/topic/391047-tn-panel-question/#findComment-5278686
VG248QE is pretty good as far as colours go...
Don't know about acer xb240h, but XL2430T or XL2420G are very good.
http://www.tomshardware.com/reviews/xl2430t-144hz-gaming-monitor,4006-6.html
http://www.tomshardware.com/reviews/benq-xl2420g-g-sync-monitor,4101-6.html
xl2411z is not very good colour wise. xl2420z+ are better. xl2430t and xl2420g use the new better panel.
https://linustechtips.com/topic/391047-tn-panel-question/#findComment-5278691
the vg248qe's color isn't that bad when you set it up right
R: 96
G: 94
B: 88
Contrast 80
and brightness 35 and it should be getting good colors (not nearly as good as ips tough)
CPU - i5 4690K @ 4.5Ghz l CPU Cooler - Nepton 240m l GPU - MSI GTX970 gaming 4g 2-way SLI l SLI Bridge - MSI Gaming 2-way L Pro l Mobo - MSI Z97-G45 Gaming l RAM - 2x8GB Vengeance Pro 2133mhz DDR3 l PSU - Corsair HX750i l SSD - 2x Samsung 840 Evo 250GB in raid 0 | HDD - WD Black 2TB | Case - NZXT H440 Red/Black l OS - Windows 10 l Mouse Logitech G502 l MousePad - XTRFY NiP lightning l KeyBoard - Corsair Vengeance K70 RGB (Red) | Headset - Asus ROG Spitfire | Monitor - Asus PG279Q - VG248QE l PCPP - http://pcpartpicker.com/p/sxTpsY | Please don't buy CX PSU for a high end PC
https://linustechtips.com/topic/391047-tn-panel-question/#findComment-5279069
