I want a build that ahs everything I need for streaming/ gaming with at all possible peripherals. my maximum would be 1100$ at most.
So do you want peripherals or no ? If yes then you want all peripheral like mouse,keyboard,monitor and window ?
Mainboard:ROG-STRIX-B360-G-GAMING/Cpu:I5 8400 /Gpu: Galax RTX 2070 /Ram: Corsair Vengeance 16 GB DDR4/ Storage:1TB HDD 2 Corsair SSD PSU : Corsair 550W/Cooling: Silverstone Air Cooler/ / Case : Corsair/Keyboard:Razer Chroma TKL/Mouse:Mionix Castor+Steelseries Qck Mass/Headphone:V Moda M100
Quote me if you when me to reply to something.
https://linustechtips.com/topic/390925-help-with-build/#findComment-5276801
maby a gigabyte G1 GTX 970?
Builds:
https://linustechtips.com/topic/390925-help-with-build/#findComment-5276911
well probably amd bc an intel i7 would prob raise the cost too much and if I want to stream or something the 8 core amd will be helpful
This is a little late but here you go. Don't get amd cpu they are not worth it the 4690k will beat out any amd cpu at almost everytask especially at gaming.
CPU: Intel Core i5-4690K 3.5GHz Quad-Core Processor  ($219.99 @ SuperBiiz)
Motherboard: Asus Z97-E ATX LGA1150 Motherboard  ($99.99 @ SuperBiiz)
Video Card: Gigabyte GeForce GTX 970 4GB WINDFORCE 3X Video Card  ($329.99 @ Amazon)
Case: Corsair 200R ATX Mid Tower Case  ($54.99 @ Micro Center)
Mouse: Razer DeathAdder Chroma Wired Optical Mouse  ($58.99 @ Amazon)
Total: $987.06
Generated by PCPartPicker 2015-06-22 01:37 EDT-0400
https://linustechtips.com/topic/390925-help-with-build/#findComment-5283322
Depends what side you want to go, AMD Or Intel.
This should never be a question.
THIS. Choosing between AMD and Intel will depend on the budget and intended usage of the build.
Echelon Mk 2.11
  • Processor: Intel Core i5-6500
  • Cooler: Cryorig H7 (With a 120 mm Thermaltake Riing RGB)
  • Motherboard: MSI B150M Bazooka Plus
  • Memory: 16 (2x8) GB DDR4 Kingston HyperX Fury (Black)
  • Video Card: Sapphire NITRO R9 390 (Stock)
  • Storage:  1 TB Western Digital Blue
  • Power Supply: 520 W Seasonic M12II Evo (with custom extensions and cable combs)
  • Casing: NZXT S340 Elite (Matte Black)
  • Fans: 2x 120 mm & 3x 140 mm Thermaltake Riing RGB
  • Display: 22 " LG Flatron L227WTG-PF LCD (OCed to 76 Hz)
  • Keyboard: Logitech K120
  • Mouse: Logitech G402 Hyperion Fury
  • Mousepad: SteelSeries QcK
  • Operating System: Windows 10 Pro (64-bit)
https://linustechtips.com/topic/390925-help-with-build/#findComment-5283595
We don't pick brands, we pick hardware based on situation and budget.
AMEN
Echelon Mk 2.11
https://linustechtips.com/topic/390925-help-with-build/#findComment-5283613
