Air flow or static pressure
Go to solution Solved by SeanAngelo,
In the process of cleaning my PC and I realize I should change the front fan on my case since its the stock msi one and isn't very good or quiet. Im going to swap it for a corsair led fan (since this one is currently led and I like the look) but I'm not sure if I should get an air flow fan or a static pressure fan. I know static pressure fans are good for radiators and other restictive air flow areas and since I have this meshing on my front panel as well as a thicker dust filter if a static pressure fan would do better in this case rathan than an air flow one.
-Thanks, Mike.
airflow
-Thanks, Mike.
https://linustechtips.com/topic/390359-air-flow-or-static-pressure/
-Thanks, Mike.
airflow
"Sulit" (adj.) something that is worth it
i7 8700K 4.8Ghz delidded / Corsair H100i V2 / Asus Strix Z370-F / G.Skill Trident Z RGB 16GB 3200 / EVGA GTX 1080Ti FTW3 / ASUS ROG SWIFT PG279Q
Samsung 850 EVO 500GB & 250GB - Crucial MX300 M.2 525GB / Fractal Design Define S / Corsair K70 MX Reds / Logitech G502 / Beyerdynamic DT770 250Ohm
SMSL SD793II AMP/DAC - Schiit Magni 3 / PCPP
Old Rig
i5 2500k 4.5Ghz | Gigabyte Z68XP-UD3P | Zotac GTX 980 AMP! Extreme | Crucial Ballistix Tactical 16GB 1866MHz
-Thanks, Mike.
I'd actually go with some BitFenix Spectre fans instead of Corsair AFs in your case, as they're both cheaper and quieter, and they're both fitted with distinctly mediocre bearings anyway.
Main Rig "Melanie" (click!) -- AMD Ryzen7 1800X • Gigabyte Aorus X370-Gaming 5 • 3x G.SKILL TridentZ 3200 8GB • Gigabyte GTX 970 G1 Gaming • Corsair RM750x • Phanteks Enthoo Pro --
HTPC "Keira" -- AMD Sempron 2650 • MSI AM1I • 2x Kingston HyperX Fury DDR3 1866 8GB • ASUS ENGTX 560Ti • Corsair SF450 • Phanteks Enthoo EVOLV Shift --
Laptop "Abbey" -- AMD E-350 • HP 646982-001 • 1x Samsung DDR3 1333 4GB • AMD Radeon HD 6310 • HP MU06 Notebook Battery • HP 635 case --
Airflow is great for what you need bud.
|EVGA 850 P2| |1440p PG279Q| |X570 Aorus Extreme| |Ryzen 9 3950x WC| |FE 2080Ti WC|TridentZ Neo 64GB| |Samsung 970 EVO M.2 1TB x3
 |Logitech G900|K70 Cherry MX Speed|  |Logitech Z906 |  |HD650|  |CaseLabs SMA8 (one of the last ones made)
