your connection will be more stable with a cabled connection, but that shouldn't be a issue if you get a decent router/access point
Speeds shouldn't be impacted, just be sure to check what the supported speeds are of the "transmitter".
System
CPU: Intel Core i7 5820K @4.5GHz - 1.230v  RAM: HyperX Fury DDR4 4x4GB 2666MHz  MB: MSI X99S SLI PLUS  CASE: NZXT H440  CPU-COOLER: Fractal Design Kelvin S24  PSU: Corsair RM1000W w/ white sleeved cable kit  GPU: MSI GeForce RTX 2070 ARMOR  MONITOR: LG 27GL850-B  STORAGE: Samsung 970 EVO 1TB M.2, Samsung 840 EVO 256GB,  WD Red 3TB
https://linustechtips.com/topic/389990-any-lost-speed/#findComment-5265729
Speed, not if its a reasonable one. Latency, maybe, but only 1-5ms.
Will it matter much and impact performance noticeably? (Online games, streaming)
CPU: i7 2600k @4.2GHz GPU: GTX 660 Power Supply: EVGA SupernovaNEX 750W 80+ Bronze RAM: 32GB G. Skill Ripjaws X
https://linustechtips.com/topic/389990-any-lost-speed/#findComment-5265750
No. As long as the adapter jn question isn't a complete piece of crap. ;)
Recovering Apple addict
ASUS Zephyrus G14 2022
CPU: AMD Ryzen 9 6900HS GPU: AMD r680M / RX 6700S RAM: 16GB DDR5
https://linustechtips.com/topic/389990-any-lost-speed/#findComment-5265857
