Enthoo ITX airflow suggestions
I'd go with a top intake if you can only fit the CPU cooler in such a way. You could go with a top exhaust, but then the CPU cooler and the fan in question would work against each other, plus you'd have the whole negative airflow thing going on. I would put that top cooler in the first of the three slots (as counted from the front of the case) however, because otherwise the air would probably just go straight from the top intake to the rear exhaust without ever going through the CPU cooler, thus rendering the extra fan utterly useless.
An alternate way would be to turn the fan on the CPU cooler around so that it blows upwards, so as to create a small area of internal negative pressure between the CPU and graphics card, which would work, but you wouldn't be able to fit any extra fans that will actually be beneficial to airflow, as the Enthoo EVOLV ITX has no bottom fan slots, and you wouldn't get the coincidental (but quite nice) cooling of the back of the graphics card that you do get with my first solution.
PS: I think you bought a very nice case with the EVOLV ITX. Is it going to be for an HTPC? I doubt you'd be upgrading from an H440 to an EVOLV ITX...
