My Benq Rl2455HM has run perfectly since I got it, but I still have a couple of issues that I need help resolving.
I haven't been able to get the settings to look right for months, and there is a weird ghosting effect that happens whenever I scroll (with Middle Click) or game.(Using HDMI)
I'm using a gtx 960 and I definitely have the latest nvidia drivers.
The ghosting won't go away, no matter of fps or other software settings, so I'm not sure what the problem is.
My monitor settings are:
Brightness: 90
Contrast: 55
Sharpness:7
AMA: High
Instant Mode: On
Senseye: Off
Dynamic Contrast: Off
Overscan: Off
and HDMI RGB Range set to full.
How can I fix this annoying ghosting? and any recommendations for more pleasant settings?
post-236326-0-26071500-1434512843_thumb.
https://linustechtips.com/topic/388195-benq-2455hm-help/
rma it. that monitor has a 1ms or 2ms response time and that should not happen.
CPU:  i7 4770k @ overclocked to 4.4ghz             GPU: Intel HD4600        SSD: Kingston V300 120GB (OS)                   Cooler:  Corsair H100i GTX
Case: Phanteks Enthoo Evolve (Black)                RAM: 2x4gb Corsair Dominator Platinium 2133mhz  HDD: 1TB Seagate                                            Mouse: Logitech G502
OS:     Windows 10                                                      PSU: Corsair RM850i 80+ Gold                                          Motherboard:  AsusZ97 Pro Gamer              Keyboard: Vortex Pok3r 3
https://linustechtips.com/topic/388195-benq-2455hm-help/#findComment-5240089
You might want to try toggling off AMA. In theory it reduces ghosting, but with my experience with a couple of BenQ monitors it just produces a different kind of ghosting. While I'm not sure how this will affect your screen, it's worth a shot.
Check out my video work at youtube.com/SuperUserTech
Acer Aspire 5750G - i5-2410m | 8GB 1333Mhz RAM | 500GB 5400RPM HDD | Nvidia GT540m
2xBenQ EW2440L | Sennheiser HD600 | Corsair Vengeance K65 | Corsair Vengeance M65 | Panasonic Lumix G7 | Panasonic 20mm F1.7
https://linustechtips.com/topic/388195-benq-2455hm-help/#findComment-5241553
