I've had my Razer Deathadder 2013 for a year and a half and I have noticed some double clicking on it. Like when I press the "+" to open a new tab, it opens 2, and if I quote someone on the forums, it quotes them twice.
01101110 01101111 00100000 01101111 01101110 01100101 00100000 01101100 01101111 01110110 01100101 01110011 00100000 01111001 01101111 01110101
Main Rig: i7-4790K | Corsair H100i | Asus Z97 | 16GB Ripjaws | 4TB WD Black/512GB SSD | x2 R9 290x | NZXT H440 | HX1000i | 6 Noctuas   [spoiler=SILENT BUILD] Silent build: i5-4460, Be Quiet! Pure Rock, Asrock H97, 8GB HyperX, Samsung 850 Evo 500gb, MSI GTX 970, Be Quiet! Silent Base 800, EVGA Supernova GS 650w
AMD CPU's. [spoiler=] thats right m8 get 420 no scoped
https://linustechtips.com/topic/387537-mouse-double-clicking/
could be an internal problem. ive had razer products fail me before
Main PC |CPU - i7-6700k|GPU - R9 290x tri-x 4gb|RAM - 16gb ddr4|MOBO - MSI z170 - A PRO|HDD - WD 1TB/240gb Sandisk |PSU - 700w Raidmax
Laptop |CPU - i7 4720hq|GPU - 960m 2gb|Ram - 8gb 2x4|Model - y50-70 Touch|SSD - 240gb Patriot drive|Display - 1920x1080 IPS touch
https://linustechtips.com/topic/387537-mouse-double-clicking/#findComment-5230096
probably just the mouse
thats what you get with most razer products
only solution is to replace it...
https://linustechtips.com/topic/387537-mouse-double-clicking/#findComment-5230105
Do you think it can be Synapse?
https://linustechtips.com/topic/387537-mouse-double-clicking/#findComment-5230115
dunno... maybe? try updating or re installing
https://linustechtips.com/topic/387537-mouse-double-clicking/#findComment-5230133
Ive had a couple mice do that to me over the years. Its probably best to buy a new one at this point. And if you get the idea that its a crap mouse please understand brand new things can fail in a day month year or decade, anything can fail and sometimes new things need to be bought hahahaha
https://linustechtips.com/topic/387537-mouse-double-clicking/#findComment-5230139
no, that shouldnt have anything to do with mouse clicks
https://linustechtips.com/topic/387537-mouse-double-clicking/#findComment-5230149
had the problem with my razer blackwidow ult and my steelseries sensei raw. un-install all drivers find an old mouse and keyboard generics only go and download the drivers again install them shut down your pc. plug mouse back in boot up pc. if that doesnt work try adjusting your double click speed
Why can't a Cleric/Priest/Bishop help a beginner KoC? Cause he's No-bless...When I post something, the thread dies.OR I'm incredibly good at giving informations,
OR I'm a thread killer.
Prolly both.
https://linustechtips.com/topic/387537-mouse-double-clicking/#findComment-5230223
I have had this exact same issue with my mouse. I contacted Razer and they sent me a firmware update for my mouse. I did that and the double clicking frequency decreased a bit but yet frustrating enough.
Then, I sprayed WD40 into the mouse one switch after opening the mouse up and it stopped double clicking altogether! No need to hassle for warranty. Just do what I said and you'll be fine.
https://linustechtips.com/topic/387537-mouse-double-clicking/#findComment-5230806
