noob pc builder need some help
Go to solution Solved by jeyemdelacruz,
http://www.tipidpc.com/viewitem.php?iid=36297418
Yes. You will get around 60 fps. Maybe more.
This guy runs it completely maxed out above 30
If you turn some things down you will easily stay above 60.
I really appreciate your help sir ty
cpu lga1150: Intel Core i5 4690K 3.5-3.9Ghz 4-Core PHP 10599.00
mb lga1150: Asrock Z97 Pro 4 PHP 5700.00
vga nVidia: Palit GTX 750 Ti StormX Dual fan, 2gb/128bit ddr5 PHP 6690.00
ram: Corsair Vengeance (Dual) 2X4gb ddr3 1866 CL9 (CMZ8GX3M2A1866C9) PHP 3730.00
here's the list of parts can someone help to build a custom gaming pc
can someone tell me if this is good gaming pc? i appreciate all your help sorry for bad english
https://linustechtips.com/topic/387109-noob-pc-builder-need-some-help/
What do you need help with?
Steve Wozniak - "Never trust a computer you can't throw out a window."        Carl Sagan - "If you want to make an apple pie from scratch, you must first create the universe."
CPU: Core i5 6600K Cooling: NH-D14 Motherboard: GA-Z170XP-SLI RAM: 8GB Patriot Graphics: Sapphire Nitro R9 380 4G Case: Phanteks Enthoo Pro HDD: 2TB Seagate Barracuda PSU: Threamaltake Smart 750W
My computer runs on MSX, Its very hard to catch.
can someone tell me if its good gaming pc? i appreciate all your help sorry for bad english
Get a cheaper CPU and a better GPU
Project Pluto
i3 4170 MSI H97 PC Mate MSI R9 380 2GD5T @ 1095MHz Kingston HyperX Fury Blue 2x4gb @ 1600MhzWD 1TB Blue • be quiet! Pure Rock • NZXT S340 Black XFX TS 550w • BenQ GW2265HM
thank you for the help its seems im too much focusing on cpu
yes. with small budgets it's best to buy a locked i5 and good gpu. much better for gaming.
can i do little oc with these setup?
you can oc gpu, not cpu. But oc'ing i5's gives almost no fps in games.
can you suggest a good monitor with these setup i really appreciate your help :) thanks
for how much?
around 5k-7k? if i play with these setup gta v with high setting will i get 60 fps?
