AMD BUILD help!
Go to solution Solved by ZetZet,
Yes it will, badly. You are pretty much better off with an i3.
https://linustechtips.com/topic/385935-amd-build-help/#findComment-5209721
Yes it is, 2x970? Get an i5, also a i3 will bottleneck it. Also can't you get a 980Ti for SLI 970 money? Just curious. You'd also save on PSU in that way.
well i already have a msi gtx 970 so i said why not get another one my psu is corsair RM 1000W witch i already have.
https://linustechtips.com/topic/385935-amd-build-help/#findComment-5209779
