Guys i just started up my PC,and theres no internet ive plugged in an ethernet cable but its not working.i havent installed any drivers and i dont have the graphics card yet,
My Specs: http://pcpartpicker.com/p/GdMfcf
CPU: i5-4460 3.2GHz quad core
CPU cooler:CM Hyper 212 evo
MB:Asus z97-k
RAM:Kingston fury black 2x4GB 1866Mhz DDR3
HDD:Western Digital 1TB 7200RPM
PSU:Corsair Builder 600W
https://linustechtips.com/topic/385922-ethernet-limited-conection-please-help/
Install the driver.
  ﷲ   Muslim Member  ﷲ
KennyS and ScreaM are my role models in CSGO.
CPU: i3-4130 Motherboard: Gigabyte H81M-S2PH RAM: 8GB Kingston hyperx fury HDD: WD caviar black 1TB GPU: MSI 750TI twin frozr II Case: Aerocool Xpredator X3 PSU: Corsair RM650
If you have drivers installed and it still doesn't work and you have no router it's probably your mac address.
please follow this guide to installing Windows on any PC. Otherwise it just won't work right.
http://linustechtips.com/main/topic/324871-guide-how-to-install-windows-the-right-way/
Please spend as much time writing your question, as you want me to spend responding to it.  Take some time, and explain your issue, please!
If you need to learn how to install Windows, check here:  http://linustechtips.com/main/topic/324871-guide-how-to-install-windows-the-right-way/
Event Viewer 101: https://youtu.be/GiF9N3fJbnE
