I figured that as this is a completely different build to my main rig (a few components will be reused), it needed a new thread.
Specs:
CPU - Intel i5 3570k
Motherboard - Gigabyte G1.Sniper M3
RAM - 16GB Corsair Vengeance Black 1600MHz (4x 4GB)
GPU - AMD Radeon 7950 3GB
SSD - 120GB OCZ Vertex 3
HDD - 1TB Western Digital Caviar Black
Case - Parvum Systems S1.0 Black (With green accents)
Fans - 4x Noctua NF-F12 (120mm), 3x Noctua NF-R8 (80mm)
PSU - OCZ ZS 750w
Watercooling hardware:
EK-Supremacy (Nickel)
EK-FC7950 EN (Nickel)
EK-FC7970 Backplate - Black
EK-VGA I/O bracket HD7970
4x EK-RAM Dominator Module - Black
EK-RAM Dominator - EN (Nickel)
Swiftech MCRES V2
Laing D5 with EK D5 X-Top
Alphacool NexXxoS XT45 240mm
Alphacool NexXxoS ST30 240mm
XSPC 1/2" ID - 3/4" OD Tubing - UV Green/Green
Deionized Water
2x Pulse Modding Kill Coil
Various Compression Fittings
Other parts:
Shakmods Green Sleeved Cables - 24 Pin Motherboard, 4 Pin CPU, 2x 6 Pin GPU, 3 Pin Fans
2x Phobya LED-Flexlight HighDensity 30cm White
BCMods on Facebook
Parvum Systems on Facebook
Case will look like this:
My current rig:
https://linustechtips.com/topic/3857-project-parvum/
Needs pics of the system.
Come and join the awesome Official LTT Star Citizen Org at LTT Conglomerat,  GTA 5 LTT Crew at LTT Conglomarate
PC Specs - 4770k - OC 4.5GHz  - GTX 780 SC - 16GB HyperX - NZXT H440 White - Corsair H100i - Corsair AX750 - Samsung Evo 250GB - 2 x PA238Q - ATH-M50 -
https://linustechtips.com/topic/3857-project-parvum/#findComment-47635
This case is awesome and I can't find a cool log build about it ! :o The lightning is this case can be so good, the side window is huge.
Good luck for you build.
Edit: Parvum website has some build logs. \o/
Thanks! The company that makes them has only just started out so they aren't very well known. Hopefully we'll see this case being used more frequently :)
https://linustechtips.com/topic/3857-project-parvum/#findComment-47643
ALL the pics, from pre built to built :P
https://linustechtips.com/topic/3857-project-parvum/#findComment-47645
How many aliens did you murder to get all that green goo?
https://linustechtips.com/topic/3857-project-parvum/#findComment-47660
Killer! I can't wait to see the final build:D
My Rig:
Case: NZXT H210 CPU: AMD Ryzen 7 3700x  Motherboard:  MSI B450 AM4 Motherboard  Memory: GeIL EVO POTENZA 16GB Video Card: MSI RX480 Power Supply: Corsair TX 750w Storage: Samsung 840 120GB And a 500GB WD BLUE Monitor: Acer S231HLbid 23" and an old Dell Mouse: RAZER DeathAdder 3.5G Keyboard: Ducky DK9008G2 PRO MX Cherry Blue
https://linustechtips.com/topic/3857-project-parvum/#findComment-48048
Agree with everyone else...that new case is gonna be awesome!
AMD Radeon R9 290X / AMD FX-8320 / Gigabyte 990FXA-UD3 / Samsung 830 128GB / Seagate 7200RPM 3TB / Corsair HX 850W / BitFenix Shinobi XL / CPU & GPU Watercooled - Thick Triple 360 Rad
https://linustechtips.com/topic/3857-project-parvum/#findComment-48052
SSD - 60GB OCZ Vertex 2 :D Your a hero :p still using a vertex2 ;)
Awesome case! I saw a buildlog on tweakers.net with this case pretty awesome :D
http://gathering.tweakers.net/forum/list_messages/1536852 L3P
http://gathering.tweakers.net/forum/list_messages/1533702 K.3nny
Sorry Dutch Buildlogs but google translate in your friend :D
https://linustechtips.com/topic/3857-project-parvum/#findComment-52828
English versions :p
http://forums.bit-tech.net/showthread.php?t=256423 L3P
http://forums.bit-tech.net/showthread.php?t=255465 K.3nny
https://linustechtips.com/topic/3857-project-parvum/#findComment-52833
Hahaha i forgot that :D Tweakers.net is my home forum for more then 12.5 years now! My username number is under 3000 and now they are on 501416 users :D
https://linustechtips.com/topic/3857-project-parvum/#findComment-52837
