HDD Problem
Go to solution Solved by nanowatt,
There were two. It picked up Super Pi as Malware...
If you found 2 there are most likely more.A clean install would be good
My HDD is constantly at full utilisation but the read/write speeds are pathetic ~ 0.1 MB/s. The computer takes about half an hour once it is turned on before I can use it.
The problem only started last night. Any ideas what is going on?
https://linustechtips.com/topic/385569-hdd-problem/
Here is the test. I ran it after I scanned and it was running better.
Did you found any malware?
Beware of him that is slow to anger; for when it is long coming, it is the stronger when it comes, and the longer kept. Abused patience turns to fury.
https://linustechtips.com/topic/385569-hdd-problem/#findComment-5205750
https://linustechtips.com/topic/385569-hdd-problem/#findComment-5205767
