CPU Overheating Whilst Streaming
Go to solution Solved by GlassBomb,
You should really consider buying an aftermarket cooler. Even something like the Hyper 212 will do wonders for your temps.
Hey,
I'm a twitch streamer and I have been experiencing a problem with my stream lately. I'm getting frequent CPU spikes whilst streaming and gaming and I'm try to figure out the problem.
Whilst idle I get temperatures of around 50-56oC
Gaming without Open Broadcast Software running: 70-75oC
Idle with OBS on: 70-77oC
Gaming whilst streaming with OBS, the CPU goes from 70oC upto 80oC then up again to 97oC (sometimes 100oC)
After around 5 minutes of gaming and streaming simultaneously, the CPU starts to spike every 5-10 seconds and causes fps drops and lag spikes.
I'm pretty sure its due to an overheating CPU.
Specs:
GPU: 3GB AMD R9 280x
CPU: i7 4790K
Memory: HyperX 2x8GB 2133MHz
MOBO: ASUS Z97-A
https://linustechtips.com/topic/385497-cpu-overheating-whilst-streaming/
Hey,
Specs:
CPU: i7 4790K
MOBO: ASUS Z97-A
Are you using the stock intel cooler? Are you overclocking your CPU? Have you cleaned the cooler since you got it? Is there decent airflow in your case?
Make sure the cooler is held down completely by all 4 locking pins, and make sure you have the cpu fan plugged in.
even the idle temps are too high, unless the ambient temp there is like 45-50°C
Tho on idle without OBS it's 50C for him.. which is normal tbh.
@TheKDub - His CPU somehow turbo boosts to 4.4GHz, for some reason. but overall, it's overheating whilist OBS is streaming to twitch.
Security Analyst & Tech Enthusiast
Ask me anything.
I'm pretty sure its secure and the CPU fan is in.
Yeah but the temps do really affect performance? I mean like he's getting spikes at 95-90C [while streaming] I believe. after like 4-5 mins of gameplay. spikes that apear as fps drops for 5 seconds and continue on going.
Ask me anything.
that stock cooler is the reason. It would be a good idea to upgrade.
Case: Phanteks Evolve X with ITX mount  cpu: Ryzen 3900X 4.35ghz all cores Motherboard: MSI X570 Unify gpu: EVGA 1070 SC  psu: Phanteks revolt x 1200W Memory: 64GB Kingston Hyper X oc'd to 3600mhz ssd: Sabrent Rocket 4.0 1TB ITX System CPU: 4670k  Motherboard: some cheap asus h87 Ram: 16gb corsair vengeance 1600mhz
An r9 280x can put out a decent amount of heat, and the i7 4790k can as well. The stock cooler on the cpu is crap.The hyper 212 evo is a beast. I got my 4790k  clocked to 4.8GHZ @ 1.25V and the evo keeps it under 75 deg C @100 load. Upgrade your cooler.
TBH 50C is far too hot, even with a stock cooler.
My wife has a 4690k and it idles at 25-30C. I know his is a higher clock, more volts and so on, but it shouldn't be such a big difference.
Even while gaming she doesn't hit 60C. That's even with a small OC of 4.2Ghz.
It's not a race to the bottom.
He's got a 280X spewing out lava underneath the CPU, and running at constant load gaming + streaming, and we know nothing of the airflow in his case. Its certainly possible it could be that high.
Anyways OP, like the others recommended, get another cooler, and possibly some more / better case fans as well.
Yeah, I ordered the 212 Evo last night :D Should fix the problems!
Idle temps should be within 10°C of ambient, even with the stock cooler, something isn't quite right here.
Figured its because it was pre-OC'ed or something like that because I didn't touch that. I was planning to OC whenever I bought better cooling... Guess I'm buying one now though :P
