is there a way i can map all application sounds separately without having to have one default device to play the sounds off game and youtube ETC  its annoying when i'm playing a game and trying to listen to something else any software i can download so i can map all my sounds separately ? Thanks
https://linustechtips.com/topic/385411-audio-mapping-help-read-plz/
I think it depends on a per-application basis.
Some applications (I'm thinking of Blizzard games, as an example) allow you specify the audio output device you want to use.
But if you're not running one of those apps, I think you're stuck using whatever the Windows default is.
SSD vs HDD Direct Comparison - Identical Drive Images | SSD Boots Windows 7 + Load 27 Apps in 1 Minute | 17 Second Boot - POST to Desktop
Razer Blade 14 (2015) | Core i7-4720HQ | 8GB RAM | GeForce 970M | 500GB M.2 SSD | 14.1" 1920x1080 Display | 4.19 lbs
