So when i go into the game, it just walks left and forward. i have unplugged my keyboard mouse and xbox remote , it still does this, i have veriftied game, out of ideas. anybody got some? i tried my mouse keyboard and xbox remote in dying light and i dont have the problem.
Computer Eqiupment:
https://linustechtips.com/topic/385400-gta-v-help/
i don't quite understand the problem, just try mouse and key for one and tell us if you face the same problem, looks like conflicting inputs.
AMD 5000 Series Ryzen 7 5800X| MSI MAG X570 Tomahawk WiFi | G.SKILL Trident Z RGB 32GB (2 * 16GB) DDR4 3200MHz CL16-18-18-38 | Asus GeForce GTX 3080Ti STRIX | SAMSUNG 980 PRO 500GB PCIe NVMe Gen4 SSD M.2 + Samsung 970 EVO Plus 1TB PCIe NVMe M.2 (2280) Gen3 | Cooler Master V850 Gold V2 Modular | Corsair iCUE H115i RGB Pro XT | Cooler Master Box MB511 | ASUS TUF Gaming VG259Q Gaming Monitor 144Hz, 1ms, IPS, G-Sync | Logitech G 304 Lightspeed | Logitech G213 Gaming Keyboard |
PCPartPicker
https://linustechtips.com/topic/385400-gta-v-help/#findComment-5203169
Yes i still have the issue, it is where the toon walks into the walk or circles, and i cannot control it.
Computer Eqiupment:
https://linustechtips.com/topic/385400-gta-v-help/#findComment-5203228
try remapping or restting controlls and select mouse and key or controller and check them individually, and remember to unplug the each other when testing them.
PCPartPicker
https://linustechtips.com/topic/385400-gta-v-help/#findComment-5203248
So i solved the problem , human error. I left my other remote plugged in when playing co-op it was left on the thumb stick.....
Computer Eqiupment:
https://linustechtips.com/topic/385400-gta-v-help/#findComment-5206677
